Old 23-01-2016, 07:55 PM   #1
Glenn08
Default Oil Slinger
I've installed a Roll Master timing chain and the oil slinger. When fitting the harmonic balancer I noticed it was bending the oil slinger. I've had conflicting advice as to whether I need the oil slinger or not? Any thoughts?
Glenn08 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2016, 09:49 PM   #2
XRtowcar
Mustang GT mmmmmm......
XRtowcar's Avatar
Default Re: Oil Slinger
I fitted a twin row timing chain in my Windsor 289.
Left no room for the slinger as it was fouling on the timing cover, so read up on the net and decided to leave it out.
Seems others do without problems.
I have become a Mustanger.
XRtowcar is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2016, 10:59 PM   #3
Tassie f100
The slinger is only there to stop oil splash from the timing chain getting sprayed at the rear of the timing case seal.if you have a good front seal you shouldn' have any leak problems
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
