Old 14-04-2016, 09:09 AM   #1
Default Do you warm up your car on cold mornings?
Would like to know members opinions on this.
On a cold morning, do you warm up your car before driving off, if so how long, or do you drive off straight away?
I've always made it a habit to idle the car for a few minutes before taking off.
Obviously, since the most engine wear occurs when the engine is cold.
Since recently installing my oil pressure gauge, it has made me more aware of how long it actually takes for the oil pressure to drop inline with the oil temperature and reaching normal engine operating temps. On a cold morning, driving at between 1500 to 2000 rpm sees the oil pressure start at around 82 psi, and after 10 to 15 minutes of driving will settle down to an average of 50 to 55 psi (using new fully synthetic 10W - 40).
On my next oil change, and coming into winter, I'll run 0W - 40, and it will be interesting to see how much lower the oil pressure will be on cold start ups.
Interestingly, I've been researching this topic, and it seems motorists are divided on this issue of warming up a car (not talking about cars that sit out in really cold climates and snow conditions).
Some say that modern cars, (since fuel injection took over from carburettors) don't need to be warmed up, as the ECU will compensate in the air / fuel ratio and timing, etc), where as older cars needed to be warmed up especially those with manual chokes before they ran smoothly.
Others say that idling a car to warm it up is not the best way, since you are not warming up the gearbox, diff and other components at the same time, so driving it straight off is better.
Then again, some say that warming up a turbocharged car is more important before giving it the boot than a naturally aspirated car, which seems obvious.
So what do you guys do?
What's your daily start up procedure ?
Thanks
Old 14-04-2016, 09:30 AM   #2
290GTP
290GTP's Avatar
Default Re: Do you warm up your car on cold mornings?
I dont warm any of my cars up, but I don't flog them either, at least until their up to temperature.
Mercury Silver 03 BA GT-P Tremec TR3650 Number 534
Herrod 4 into ones, Manta Exhaust, CAI, K&N Filter, Mellings oil pump, 19" FPV alloys, Bilsteins, Kings, tuned by Autotech, 272rwkw
RIP Fish 15/1/73 - 9/2/19
290GTP is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 09:39 AM   #3
Grippy
Racing improves the breed
Grippy's Avatar
Whether it's needed these days or not I'm not sure, but I was always bought up to warm up my cars for a short period, and more importantly to never give them a hard time until they're up to temperature.
1970 Mini Cooper S Historic Group Nc Touring car
1964 Mini Cooper S Historic Group Nb Touring car
2024 Subaru Outback Touring XT
Victorian Hill Climb Championship
Grippy is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 09:44 AM   #4
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
This has been covered mant times. Modern engines dont need to be warmed up. Drive the car sensibly till the temps get up, the engines are also designed to warm up quickly while driving. Your doing more damage letting it idle.
Also while you get your eng up to temp the rest of the drivetrain is still cold.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 09:53 AM   #5
Is this because, the fuel / air ratio is running richer on cold startups, and the extra petrol is "washing away" the oil on the cylinder walls, causing less lubrication and greater wear?
Old 14-04-2016, 09:59 AM   #6
Vesper Martini
Vesper Martini's Avatar
So long as your engine has the specified oil (or better) and its changed at the correct intervals.
Its designed to operate from cold right through to hot.
but keep warming up your old classics
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:03 AM   #7
Vesper Martini
excessive idling causes Cylinder Glazing
"The glazed cylinder wall causes rings to "skate" on the highly polished finish and discourages the minute amount of wear which is necessary to mate piston rings with the bore"
not sure its its more of a big diesel problem, But its really noticeable on old yard Trucks that never get on the road.
They Puff away with white smoke
Old 14-04-2016, 10:05 AM   #8
The Yeti
The Yeti's Avatar
my modern cars I just take it easy till the temp gets up a little, my old splash feed stuff I let warm up a little (just a few mins idling) then off I go
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:05 AM   #9
XR6WGN
XR6WGN's Avatar
I lived in Canberra for a couple of years and during winter I'd give all mine a couple of minutes - start it, put seat belts on etc then move off but most of my cars back then were carby, not fuel injected.
476 EF XR6 Wagons - 198 were Manual
2010 Anniversary XR50 in Sunburst - 6spd Manual
My Gallery Photos Here
XR6WGN is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:19 AM   #10
Sioso
irregular member
Sioso's Avatar
I think this is what may have contributed to an engine failure I had.
Brand new car, used to let it warm up for 3-4 minutes every morning before driving off.
Engine failure at 7,000k's!
As others have said, no warm up period just take it easy until it comes up to temp.
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:27 AM   #11
Big_Daz
Don't bother with my Mazda, but I don't give heaps until it warms up..
When I had my FG Turbo I would just not give it a bootful and use minimal boost until warm...
My first car was a Carby Astron 2 Magna wagon which I had no bloody choice but to warm up before heading to school... Was an absolute pig on cold mornings until you got some temp into...
2008 FG XR6 Turbo ZF In Sensation - Gone, but not Forgotten....
Hers: 2024 Ford Everest Platinum in Equinox Bronze
His Daily: 2020 (MY21) Kia Sorento GT-Line in Mineral Blue
His Weekender: 2017 Commodore SSV Redline manual in Light My Fire Orange
Big_Daz is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:32 AM   #12
crainger
crainger's Avatar
Have always, hoped in. Primed the fuel pump (in my old VL) and started. Seat belt on. Mirror check and off I go.
My understanding is the ECU has warm up cycles. I know my old VL wouldn't shift in to OD until I'd been driving for 5-10 min. I just avoid spirited driving until warm.
A guy I worked with would warm his XR4 up for 10-15min of an afternoon. Although he did thrash the hell out of it.
Our neighbour would warm his Land Cruiser up from 0530 to 0600 every morning. If I wasn't already up at the time I'd be sneaking out to turn it off.
crainger is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:39 AM   #13
DBourne
DBourne's Avatar
Start, then let the car sit for about 2min, then drive sedately until temps are up, then she's good to go.
Also, drive sedately for the last few K of the trip home, before turning it off.
flickr
DBourne is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:43 AM   #14
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
In winter in my Focus i start it up and let the heater run for about 10-15 minutes to defrost the windscreen because its iced over.
Other than that get in and drive her.
The F100 is a PITFA when its cold so it has to warm up first.
Old 14-04-2016, 10:44 AM   #15
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
I do. Both my EL montys are high mileage. It is just sympathetic to the car.
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:44 AM   #16
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Do you warm up your car on cold mornings?
I do, and will continue to do so. I don't think the ambient temp ever gets cold enough in the topend to call it cold, but when the car is at ambient I do.
Nothing too drastic though, just start the car and idle for 3-4 minutes before backing out of the driveway.
Idling can't hurt as long as it's not for extended periods of time.
How long do you sit in one spot idling in peak hour traffic...
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:47 AM   #17
CoupeKing
There was a similar discussion a while back. What I got from it was that with most older cars you have no choice but to warm them up a little for them to run properly, and with the newer cars, just driving them normally is warming them up.
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:56 AM   #18
Ben73
Ben73's Avatar
I warm mine up for about 20 seconds or so.
I will just drive easy until it's up to normal temp no matter what the outside temp is.
No way I would ilde my diesel to operating temp. It would take 30 minutes I reckon.
Gentle driving in the middle of winter takes about 10 minutes to get the temp up towards normal.
Ben73 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 11:09 AM   #19
xurbanx
xurbanx's Avatar
I warm it up for the same length of time it takes me to book the morning's parking - usually about a minute or two.
[Old] 2004 Ford Fiesta LX
[New] 2014 Ford Fiesta ST
xurbanx is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 12:25 PM   #20
LyleXR8
I hit the key and straight into it, my neighbours already hate my car at 4.30 am, they'd hate me more if I idled it for a couple of minutes
LyleXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 12:26 PM   #21
Qwerty321
Qwerty321's Avatar
I always aim to let it warm up for a minute or two before driving it in the mornings, but in reality this rarely ever happens. I'm always running late
Project/Fun Car - BA MkII Fairlane Ghia
Daily Driver - Volvo V50 2.4
"If in doubt, flat out" - Colin McRae
"Horsepower is how fast you hit the wall. Torque is how far you take the wall with you"
"Cheap, fast and reliable. Pick Two"
Qwerty321 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 12:32 PM   #22
Sox
RIP...
Sox's Avatar
Idling an engine to warm up is worse than driving off cold.
There is no compelling reason to warm up a modern car engine by stationary idling.
We used to idle our engines because they wouldn't run well with carburettors when cold.
Modern engines are ready to drive immediately, and better for it.
Engines warm up much faster when driving than idling.
Not only that, the rest of the drive train, transmission, diff, tyres, also warm up at the same time.
Idling an engine to warm up is not only totally unnecessary, but wasteful of fuel.
Almost all car manufactures now encourage driving immediately.
Obviously don't thrash the engine until it's at operating temp.
Oval Everywhere...
Old 14-04-2016, 12:38 PM   #23
LTDHO
The one and only
LTDHO's Avatar
I can't think of a quicker way to glaze up the bores than to let it idle up to temp.
I drive straight away but no hard acceleration, etc.
Tuned by CVE Performance
Old 14-04-2016, 01:10 PM   #24
sprintman1
Never idle to warm up. Cyl I der washing with raw fuel and fuel dilution of the oil for other problems. Drive reasonably immediately after start up until the oil is hot which takes a fair while after water temp gauge indicated running temp. Oil temp gauge a useful addition to any vehicle.
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 01:11 PM   #25
mike_nofx
mike_nofx's Avatar
The owners manual of my common rail diesel says "Allow engine to warm up at idle speed for approximately 7 seconds at temperatures of 25C up to 17 seconds at -25C"
As for my Falcon, I've never once warmed the engine up by idling and its done 350k trouble kilometres.
Waste of time to warm up a modern engine. If you drive every day and warm the engine for approx 3 minutes, over a 60 year life of driving, thats 1100 hours of sitting inside a warming up car haha
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 01:16 PM   #26
Trump
bitch lasagne
Trump's Avatar
Been done before:
http://fordforums.com.au/showthread.php?t=11419500
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 01:17 PM   #27
Legit290
Legit290's Avatar
Hot day cold day i warm mine up for 2 minutes before i drive off
11 second car with a 12 second driver
Blown BA GT mk 2 manual in Envi
Legit290 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 01:31 PM   #28
mike_nofx
mike_nofx's Avatar
Should make a poll for this thread
Old 14-04-2016, 01:36 PM   #29
FPV0137
I make a habit of letting my cars idle for a bit while cold before I go anywhere. And then wont even go past 3000rpm for the first 10kms.
As for the work cars, they're half rooted anyways, and being n/a 4cyl pieces of crap no one cares enough about to even service, I don't bother lol
FPV0137 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 01:56 PM   #30
Tassie f100
Never warmed an engine up yet.By the tlme I turn around and go down the driveway all is ready to go.If I start up and idle it takes 15 minutes to get up to norm temp.If I get in and drive it takes about 4 minutes.
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
