02-07-2016, 03:24 PM | #1 | |||
Render unto Caesar
http://www.pistonheads.com/news/ph-g...py-shots/34488 http://www.autocar.co.uk/car-news/ne...C3%BCrburgring
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
29-07-2016, 11:03 AM | #2 | ||
Render unto Caesar
Video of the beast testing.
05-06-2017, 01:25 PM | #4 | ||
Render unto Caesar
Shotgun ride
https://drivetribe.com/p/OUNZCgD0TFS...source=organic https://www.topgear.com/car-news/sup...che-911-gt2-rs
06-06-2017, 02:09 PM | #5 | ||
irregular member
https://www.evomagazine.com.au/new-p...-rs-prototype/
Too early to call on how it drives, but from the passenger seat it feels every bit as mad as a GT2 RS should Ten years have passed since the GT2 RS badge has graced the backside of a 911 and it’ll do so again soon. Officially, that is. Porsche has finally confirmed the existence of a new turbocharged flagship, and we’re along for an early ride in the prototype. If you’ve a decent enough memory you should remember the details of the old 997 GT2 RS. It was a 456kW, turbocharged, rear-drive, manual car with a 3.5 second 0-100km/h time, 0-160km/h time of 6.8 seconds and a lap around the Nurburgring in 7 minutes 18 seconds. That’s ten years ago, remember, and this new GT2 RS promises lunacy on a new level altogether. Sub 3 seconds to 100km/h, 200km/h comfortably under 9 seconds and a top speed in excess of 340km/h. It achieves that by the same pick and mix of 911 Turbo and GT3 RS parts selection, with a lot of new bits added to justify both its inflated price and status as well as cope with the sizeable leap in performance. Technical highlights We’re so early in the GT2 RS prototype Porsche hasn’t actually gotten around to homologating it for production, so it’s being justifiably vague about specifics. We know the engine’s based on the Turbo S’s 3.8-litre twin-turbo unit. To that the GT department has added bigger turbos, upped the boost, added a bespoke lightweight exhaust and revised the internals to cope with the increased power. There’s also a new water spray cooled intercooler system, which comes with a separate 5-litre tank that’ll need refilling after three hot laps of the Nurburgring. It drops the intake temperature by as much as 15 degrees to allow the GT2 RS its huge hike in power. As Preuninger says: “it’s not just a chipped Turbo S, definitely not, it’s a completely re-engineered car.” Pre-homologation Porsche is stating its output as ‘greater than’ 478kW and 750Nm. Nobody’s denying those figures are fairly conservative, and in the best GT2 RS tradition the expectation is they’ll be a good deal more than that. The GT2 RS’s top dog status is secure then, but Preuninger’s promising a bit more sophistication than its unruly 997 predecessor. “I like this absolute brutal power that this has, but it’s a joy to drive on the track, it’s so precise, it’s so nimble and agile and a lot easier to drive than a 997 GT2 RS, which was a brute, to the point where you couldn’t handle it sometimes. This one has more power, way more power,” says Preuninger. Driving the rear-wheels via a seven-speed Sport PDK, that’s a deliberate, and necessary decision. Necessary for the engine’s torque output, and deliberate as it’s faster. Preuninger admits GT cars wearing an RS badge will always be about outright speed – so PDK only. There’s a feeling he’s been stung by criticism from some on the GT department’s recent focus on driver engagement (the manuals in the R and GT3) rather than outright speed. The GT2 RS is very much the riposte, Preuninger saying it’ll not just beat its internal competition’s performance – that Turbo S and old GT3 RS – but all its rivals. We can expect a very hot lap from W. Rohrl in time then, which given the GT3’s 7 min 12 capability with a 110kW deficit should see the GT2 RS dip under the 7 minute barrier. Helping Walter will be suspension that to all intents and purposes is pinched off a 911 Cup car, in Nurburgring specification. There’s upside down race dampers, every link, with the exception of a single connection on the rear-wheel steering system, is rose jointed. Preuninger says the spring rates are double on the front axle compared to that of the GT3, the rear significantly higher, too. The PDK allows the use of Porsche’s electronically controlled locking differential, allowing anywhere from 0-100 per cent lock up. The wheels, 20-inch front, 21 at the rear, are shod with 265/35 ZR20 and 325/30 ZR21 Michelin Pilot Sport Cup 2 tyres specifically developed for the GT2 RS. Weight is down, via the usual GT department means. The expectation is under 1500kg, though given its huge output Preuninger says it’s just not been necessary to remove every last bit of sound deadening. Nor has the rear glass been replaced with Perspex in the ultimate pursuit of weight loss. The glass is thinner and the GT2 RS comes with Gorilla Glass – the type used on smartphone covers – which will please US customers, where Perspex windows are illegal. Yes, you can still delete the a/c, radio and infotainment, but nobody will. If you’re mass obsessed Porsche will offer a Weissach pack, which drops 30kg off the kerbweight. That’s possible thanks to some exotic metals, including magnesium wheels – these alone responsible for a 12kg drop over the standard alloy ones. The Weissach car’s cage is titanium for a 7kg saving, while the GT department has found a way of making the roof out of carbon fibre that’s lighter even than the standard lightweight magnesium roof that’s pinched from the GT3 RS. PCCB features as standard, the front discs cooling aided by the NACA ducts positioned on the bonnet. It will, Preuninger promises, look significantly different to the GT3 RS (and hence the prototype here), with GT2 RS carbon elements featuring heavily, from the vented outlets above the front wheels to the side intakes, front splitter, rear diffuser and more. Even so, downforce should be around the same as the GT3 RS. Engine, performance and 0-100km/h time A heavily tweaked 3.8-litre flat-six from the Turbo S sits on active engine mounts in the back of the GT2 RS. It’s got a bespoke intercooling system with a water spray and a similarly exotically specified exhaust which, with the flaps open at heat, will give the rapidly reversing traffic behind a view the orange glow of hot catalysts via a pair of massive exhaust pipes. Porsche is quoting 0-100km/h of less than 3.0 seconds, it likely to be around 2.9 given the rear-wheel drive, though above that Preuninger promises it’ll monster everything, the 0-200km/h time comfortably under 9 seconds. We’d love to know, but we’re strictly belted into the lightweight fixed-back seat on the side of the car without a steering wheel or pedals. It’s quick, hugely so. The engine sounds magnificent, too, which given it’s a turbo is very welcome indeed. We can’t believe we’re saying this, but it feels quicker still than that bat**** fast Turbo S, the way the GT2 RS rearranges your internals and makes you spit out expletives is like little else we’ve been in. It feels 918 Spyder-elastic, if without the hypercar’s electrically-assisted immediacy. A quick ride on the autobahn sees the numbers pile on quicker than the electricity meter at an AC/DC gig. The brakes are mighty, the stability unerring, it even rides with civility – though we’ll take a pass on that until we can get it away from the flatteringly smooth tarmac around Weissach and actually drive it ourselves. On the country roads Preuninger drives to work on, the GT2 RS is sensationally quick, the traction obvious, and his assertion that it’s as agile as the GT3 RS difficult to argue against from where we’re sitting. Verdict, price and rivals Very early to call, but the prototype demonstrates enormous promise, and Preuninger says the last 20 per cent of development happens once the pre-production cars run off the line. That’s happening in the next few weeks. A different type of GT Division car, then, as it should be to live up to that reverential badge. As it stands, this prototype could head the range, so we’re more than a little bit keen to experience all this ferocity with even more polish in the eventual production version. Prices? Who knows, except we’d not be too surprised if it starts with a five, especially if, as you inevitably will, you go for the Weissach pack. Rivals include anything that’s been around the Nurburgring with a view to setting a fast lap, though at this level it’s irrelevant, as the GT2 RS will be parked alongside them in owner’s garages. That is, assuming Porsche can satisfy what’s likely to be strong demand for it. |
20-06-2017, 01:41 PM | #6 | |||
Render unto Caesar
28-09-2017, 01:51 PM | #8 | ||
Amazing- felt like I was in an F1-driver very very good. Thanks for that. Interesting how all these best laps are done at sunset- ie roads heated up and retaining heat, but outside ambient temperatures dropping for best engine HP?
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
28-09-2017, 03:09 PM | #11 | ||
That's a monster time and I bet they could get a little more out of it and challenge the over-all record (almost got it on that run), and ten seconds faster than it's bigger brother in the 918 Spyder.
28-09-2017, 09:04 PM | #13 | ||
Little bit of a secret but i'll let it out now just for fun.
Porsche also designed/engineered the H.D V-Rod engine. Have never ridden a V Rod but have seen plenty on sidelines and they do go very well indeed! |
30-09-2017, 04:52 PM | #14 | ||
I think super cars are over rated. I own two of them. A lamborghini gallardo LP550-2 and a Nissan GT-R r35. They are great cars but there not worth it. I own a couple of falcons as well and to tell you the truth the falcon is more exciting. Around a track of course the falcon will be slower. But a tuned F6 on the street is a great package. Does everything well.
2 users like this post: |
30-09-2017, 05:48 PM | #15 | |||
irregular member
30-09-2017, 06:24 PM | #16 | |||
They are too highly strung for the majority of our roads. But awesome on the right bitumen.
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
01-10-2017, 08:36 AM | #17 | ||
01-10-2017, 12:37 PM | #18 | ||
Render unto Caesar
Ok, so these are track cars for the road, so yes, built for going insanely fast around a track. Nothing more.
Want a cruiser, Porsche have a range of cars for that too, want a 911 that is stupidly quick and comfortable? Carrera 4S or even better the Turbo (S). Seem to be fine on our roads. Wheels or was it Motor, anyway, they took a 911 Carrera around AU, only complaining about tyre noise. Looking forward to the F6 vs GT2 RS 'ring race.
01-10-2017, 02:01 PM | #19 | ||
Long live the GT !
Mind blowing performance for a road legal car.
I play Assetto Corsa a lot and recently managed a 6:55.7 in a LaFerrari ! Just $696,261 driveaway https://photos.app.goo.gl/f1GK64ogQgGHZID82
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint "Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
01-10-2017, 02:20 PM | #20 | ||
Ford screwed the Falcon
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
01-10-2017, 02:29 PM | #21 | |||
Bathed In A Yellow Glow
Horses for courses I guess. . |
30-03-2019, 01:49 PM | #22 | ||
Even faster version of the GT2 RS
25-06-2021, 01:19 PM | #24 | ||
You might be surprised. I was lucky enough to get a ride in one of these a couple of years ago. On the same bit of twisty, deteriorating country road I drive all the time in my G6ET. I know the road well. The driver (although very good) didn't. I was gobsmacked at how stable this was over the bumps. Going through corners at twice the speed I do when at 8 tenths with ease. Bumps mid corner that upset the G6ET didn't trouble the Porsche. I would be warning the driver with "there's bumps around this corner", expecting to end up in the scenery. I was amazed at how well sorted the chassis was. Floored. Apart the the blistering acceleration it was how well sorted the suspension was that got me. It was a noisy beast though and if you gave me the choice of driving Adelaide to Melbourne in my G6ET or the GT2RS I would take mine everyday. However if I was told you can drive as fast as you like......different story. P.S. My organs are still finding their way back to their rightful positions.
25-06-2021, 08:00 PM | #25 | ||
I have never really been a fan of the 911 Turbo or GT2, they seem to lack the soundtrack of the naturally aspirated GT3.
I'm loving the more sedate looking GT3 Touring at the moment, the engine in that is more my style. I'll have mine in Guards Red with the Bordeaux red interior please.
PX MK II Ranger FG XR6 FG X XR8 Mustang GT T3 TS50 - gone but not forgotten |
