06-06-2017, 02:59 PM | #1 | ||
Hi Guys, awesome forum and would like to ask for help.
My daughter drives an 04MY Fiesta 1.6 FYJB engine. On her way home the other night she said it kept stalling on her but managed to get it home. It also came up with EAC Fail in the dash. Had a look at it and found no DTC's. Only found freeze frame data for P2176. I did find a split hose which I taped up at this point so is no longer leaking but this car will still not idle. It will start and then idle on it's own but if you increase the revs then let it go it stalls. The car also drives really well but when idling it seems to run really rich and the front 02 sensor reads rich but when RPM increased the sensor then fluctuates as it should. Can anyone confirm the re-learn for the throttle body as I have tried one and it didn't work. I am in the process of getting a second hand throttle body to put on this car and test but want to confirm the the re-learn. Thanks for reading and thanks for any advice given. I will update you as this diagnostics progress |
