Hi all.
Interesting one here- I have a mk5 cortina ghia. It has two interior ceiling courtesy lights. Both have the on-off-door setting. But the door setting doesn't seem to work. The bulbs are fine because they work when switched to on, I have cycled each door switch but no result. Any ideas of why the door setting isn't working?? |
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
The usual cause is that one of the actual door switches is either jammed in the off (closed) position or the wiring to them is damaged.
Cheers Russ
Observatio Facta Rotae
