15-03-2018, 09:15 AM | #1 | ||
Has anyone come across a problem I have with the brake fluid reservoir cap leaking when the car is parked on a downward slope , the cap has a vent hole in the rubber seal as well as a slot cut into the cap and due to the flat shallow shape of the reservoir the fluid when parked on a slope the fluid slowly weeps out. I have already replaced reservoir including the cap and seal.
15-03-2018, 11:44 PM | #2 | ||
Yes, to alleviate this you have to fit an adapter neck that sits between the reservoir and the cap to lift the height of the cap, part number BV61-2K148-AA and make sure you have the revised reservoir cap BV61-2162-AB.
16-03-2018, 02:25 PM | #3 | ||
Does it make the area look anything like this?
Current Rides: HIS - 2018 PDe Hyundai i30 N 6M - Performance Blue HERS - 2020 MR Mitsubishi Triton GLX-R 6M - Red Past Rides: 1997 EL Ford Fairmont 4A - Navy Blue 2006 BK Mazda 3 SP23 5A - Carbon Grey 2010 LV Ford Focus XR5 Turbo 6M - Frozen White 2013 LW Ford Focus ST 6M - Panther Black |
16-03-2018, 06:35 PM | #4 | ||
Thanks to GTLEGEND seems you really are a legend! I am currently chasing the parts almost seems like it should have been a recall item or at least the parts/service people should have been aware of the issue when I sourced the reservoir
21-03-2018, 05:42 PM | #5 | ||
You would think the parts guy would have known, that is if they were up to speed?
How did you go getting the parts? |
09-05-2018, 06:57 PM | #6 | ||
Follow up on this
I got the extension and the cap pretty sure the cap is identical , I asked the service reps at the Ford dealer, Bayfords and Courtney and Paterson they couldn't have been less helpful the parts guy at C&P was the only one with any idea the extension was $52.00 and the cap $8.00 I has attached photos if any one else is having the same issue |
09-05-2018, 10:56 PM | #7 | ||
Yes hard to find good help these days. Hard to believe that a lot of people that work in service and parts don't actually have a passion for cars in general, its just a job that they reluctantly turn up to because they have to.
Glad you got the bits, I gather the parts guys were surprised when you supplied the part numbers lol Did it fix your problem? |
09-05-2018, 11:20 PM | #8 | ||
Looks good so far!
09-01-2019, 08:59 AM | #9 | ||
Update Jan 2019 problem resolved haven't had to touch the brake fluid since fitting the extension
09-01-2019, 08:17 PM | #10 | ||
So we can all assume its fixed for good!!
That's good news, glad it worked out for you!! |
