Old 11-12-2018, 09:50 AM   #1
hugebean76
Default LW2- Aux Power Pickup
Hi all, apologies if this has been covered before but I have found threads for the LV Focus on the same subject but not the LW2.
I want to pick up power for a dashcam. I was going to tap into the 12v source in the front console (easy to get to). I have two questions:
Does anyone know the what colour wire is power to the 12v source?
Is there another 12v source that can easily be picked up that is switched to accessory?
hugebean76 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2018, 05:30 PM   #2
marg99
Default Re: LW2- Aux Power Pickup
one suggestion some dash cams turn off automatically if power is cut otherwise they stay on all the time so check you use a power source that is only on when the car is on.
Old 11-12-2018, 11:05 PM   #3
stefcio007
I'm using a fuse tap (with 3.1A USB ports) on fuse 85 in the passenger footwell.
Only supplies power when the key is turned. No power when key is out.
Fuse 85 is described as
Passenger air bag deactivation indicator (PADI), front seat heater switch, heating module (manual A/C), air quality sensor, radio, in-car temperature and humidity sensor, voltage quality monitoring, front parking aid camera, moonroof, PTC heater, parking heater
so find a fuse with a similar description and you should be good. I had a hard time as most fuses there either can't be tapped into due to the design of the fusebox or have constant 12V.
This is the fuse tap with USB ports that I bought. http://s.click.aliexpress.com/e/chS1h7TS
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2018, 12:14 PM   #4
hugebean76
Hi all, I did a bit more digging around. LW2 is the Australian designation for the Focus, a lot of English websites just nominate the Focus as an MK3.
So I found a British Ford Focus forum that gave me a how-to.
https://www.fordownersclub.com/tutor...all-focus-mk3/
Note that it utilises the same method as described by stefcio007 (thanks) but with a little more detail.
The parts that Stefcio007 described in his post can be substituted for the following:
https://www.jaycar.com.au/double-min...e-tap/p/SF5125
https://www.jaycar.com.au/standard-d...older/p/SZ2040
https://www.jaycar.com.au/under-dash...ocket/p/PS2016
OR
https://www.jaycar.com.au/twin-usb-p...-3-1a/p/MP3616
OR
https://www.jaycar.com.au/twin-usb-p...-3-1a/p/MP3618
