Old 23-01-2019, 08:03 AM   #1
TheMoonman
Default 2004 Him Module
Hi all,
I have an 04 Falcon. I have an issue with the HIM module.
Every now and then the HIM module starts to click when you turn the car on... it doesn't do it all the time and often stops by itself.
I don't want to remove the dash and replace the whole unit as it cost heaps and it doesn't do it all the time.
I have fount the small grey plug on the side of the module, if I unplug it when it starts clicking... it stops and I plug it back in... problem solved.
I want to put a small on/off switch on the plug. Does anyone know which wire is the main feed to the him module that I could put a switch on...
Hope this makes sense.
Bruce Swallow
TheMoonman is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2019, 08:18 AM   #2
raceteam
Default Re: 2004 Him Module
Wiring diagrams are in the Tech Resources
raceteam is offline   Reply With Quote Multi-Quote with this Post
