07-08-2019, 12:13 PM | #1 | ||
Hi everyone,
Tried searching for thread would not work. Low km -33k 2014 focus has a rough idle. Any help please |
07-08-2019, 02:00 PM | #2 | ||
have you cleaned the exhaust gas re-circulation valve?
07-08-2019, 05:27 PM | #3 | ||
Check for vacuum leaks around the inlet manifold , spray throttle body cleaner around the manifold flange and associated parts to see if the engine picks up in revs at idle.
If it does then you need to pin point were the leak is . IE the inlet gasket to head , injector O ring etc
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
07-08-2019, 05:39 PM | #4 | ||
Check for collapsed engine mount (the one under the coolant reservoir). You can tell if there is any rub marks between the bottom of the rubber and the top of the lower aluminium housing. if there's rub marks, its collapsed.
Has this vehicle had a clutch replaced? If so could also be that the clutch mounts to the flywheel have not been torqued up to the right torque and in the right sequence. Also check spark plugs and coils. |
