So my daughter's car has the stop-start feature.
It's never driven in huge traffic-jams, so I suppose it is most effective at traffic lights, but even then I'm not sure how much its saving, if anything. What concerns me is the fundamental gut feeling that this is stressing a lot of components. This is not a hybrid, it's a TD with a starter-motor. The petrol version uses the special stop-start oil 0W-20, but I think this uses a fairly normal 5W-30 Diesel Oil. They seemed to be aimed at providing quick protection at start, but I wonder if it isn't sacrificing protection at the top end? We've driven it long enough to get an idea of the fuel economy, so I'm thinking of switching off the feature for a while and see if it makes a huge difference. Given diesel run very lean at idle, I doubt it will.
Time to Make the Hippies Cry Again |
I reckon its just a sales gimock so the round town economy is better than the opposition , long term you pay the price by the affects it must have on reliability , a few years ago we looked at a golf and the salesmen said you cant permanently turn it off you had to do it each time you drove it ....what a PIA
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
3 users like this post: |
On some of the mazdas with it you can permanently disable it by miss adjusting bonnet sensor or something so the car thinks bonnet is open, saves having to turn it off all the time.
The mazdas stop start doesn't use the starter aparently, it picks a cylinder near top dead center, injects fuel and lights it off to get it going. I think thats right anyway been a while since i read about it. I agree though its useless tech that is annoying
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
It is a feature of our CX-5. I absolutely hate it and turn it off when I get in the car. But it doesn't bother my wife. I also hate the shudder as the car starts again.
For me. It always seems to cut out at the worst possible time. From observations, there appears to be two position switches on the brake pedal. I was taught to ease off the brake pedal so as to stop the car gently. This doesn't trigger i-stop. But I must have a habit of giving the pedal a push just before transferring my foot to the accelerator, and this triggers i-stop. I don't know if this is true (or not), but apparently, you can ask the Mazda dealer to give you are reading from the on-board 'puter to find out how much fuel i-stop has saved. Allegedly, the fuel savings outweighs the additional cost of the battery. As for wear and tear. It definitely puts more strain on the battery. From what I have read on the internet (which may or may not be true), under ideal circumstances a typical car battery is good for 30,000 starts whereas a stop-start battery has to be good for 80,000 starts. As for the rest of the mechanical, I don't think stop-start has a noticeable effect on component life. Another reason why I cannot wait for technology to deliver a reasonably priced EV. |
what about the poor little turbo thats working hard pulling up a hill then the lights change and it sits cooking with no oil flowing through it , then the engine starts and the turbos full tit before the oil gets to it
#6 | |||
The Stop/Start system is designed to reduce vehicle exhaust emissions, not to reduce vehicle running costs. Which vehicle would be producing more exhaust emissions? A - The stationary vehicle with the engine idling. B - The stationary vehicle with the engine off. Consider the number of vehicles world wide fitted with a Stop/Start system & the amount of exhaust emissions that are not entering the atmosphere. The engine oil viscosity is also related to lowering exhaust emissions, not to make the engine easier to start or to reduce engine protection. |
Start Stop has been around for a while. Long enough to prove it can be reliable.
As for fuel savings, well that is purely going to depend on how it is driven and how often you are stopped. I don’t mind it, I’d have the tech and use it. May as well have the engine off when not in motion then sitting there wasting juice.
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
As Whynot explained about how much pressure you put on tge pedal.
I also have a CX5 and wife has a Mazda SP25, both with istop. If you pull up to lights and come to s stop, just enough pressure to hold the car stationary and the engine will keep running, but push a bit harder and istop kicks in. If I know I have a long wait I'll use istop, but if I know it's only going to be less than a minute then gentle on the pedal.
jaydee351 4DV8 |
![]() Join Date: Dec 2004
It's on there so car manufacturer's can claim the minimum level of emissions for city driving. If a car has a stop/start system that remembers to stay off, emissions are calculated as the average between having a s/s and not having a s/s active. With a system that reverts to ON every time the car is started, emissions are calculated based on driving with s/s active.
Supposedly you can save between 4 and 8.7% in fuel by using it according to this 'scientific' test: https://www.youtube.com/watch?v=dFImHhNwbJo For me, it's annoying, borderline dangerous (locks the steering, and there can be delay if you need to pull off in a hurry, plus it makes you look like a tight ****). It's the first thing I turn off when I jump in my car, and thinking of getting a permanent aftermarket disabler for $160 as well.
My Resume: Current: Alfa Romeo Giulia Quadrifoglio in Vulcano Black MY18 Black WRX STi Spec-R Previous: '16 White FGX XR8 '09 Black FG FPV GT 5th Anniversary '04 Blueprint BA XR8 '97 Mocha Foam EL Fairmont |
4 users like this post: |
Thailand Specials
I can't stand that start stop crapola, one of our company cars had it - Mazda 6.
Put it in sport mode and it wouldn't turn off at the lights. |
Have it in the Honda civic turbo diesel 1.6 litre- pain in the butt, when goes off the start up is a delayed pregnant pause. Puts strain on started motor and battery, let alone other components as others have said. Always turn it off.
In my Fiesta ST Mk8 also has stop start. Far quicker to turn engine back on when stopped, so is not that big a deal. But I drive the Fist in Sport or Track mode daily where it is turned off automatically so all is good ![]()
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
#12 | ||
So if is a stinking hot day what happens to the air conditioning. Does your phone blue tooth connection disconnect when it restarts and does the radio Cut out.
#13 | |||
Thailand Specials
The car stays on ignition so all your in car entertainment stuff functions as normal, the engine just shuts off. I find it highly annoying, particularly on approach to busy roundabouts. |
#14 | |||
There are a number of parameters that the car needs to meet before the engine is turned off. Air con requirement, engine temp, battery voltage, even steering wheel angle, brake pedal pressure, list goes on.
#15 | ||
My Habit is hit engine start button then hit auto stop disable.
Having auto stop shows how short most of your stops are. Way too many times I’ll let off the brake as soon as the engine shuts down then the delay seems to be worse than the normal. Even the normal delay is annoying unless you are a few car back from the lights so you can let off the brake a little earlier than normal |
#16 | ||
the best thing on the autos is that a slight relaxation of the brake pedal will restart the car. Manuals are a pain as you have to dip the clutch. or just turn the whole thing off.
Personally - I hate the damn thing but like many other emissions control devices it's here to stay so we'll just have to get on with it. Pretty sure though that my heavy accels outweigh any s/s benefit to the environment ![]() |
#17 | ||
The work van has this.
I don't like it. It adds 1-2 seconds of delay. Makes me really nervous - is it going to start this time? Luckily you can disable it or you don't push the brake pedal all the way so it doesn't activate. The amount of fuel you are going to save is minuscule. Probably the starter motor and engine will wear out faster too when you frequently start/stop. But who really cares.. They make them cheaper and doesn't really matter if the car fails. If it can make it till the warranty period is all that matters. They just sell another new one ![]() Last edited by gkhn; 13-09-2020 at 06:56 PM. |
#18 | ||
It's easy to disable permanently with Forscan.
#19 | ||
0o\==^==/o0
![]() Join Date: Oct 2008
I really think the best way emissions can be improved, is not by shutting down an engine while idle, but to improve the synchronisation of traffic lights. Why can’t lights be set to change to green to keep a better flow of traffic. I understand that it is not always possible in heavy peak hour, but to stop at a red light at 4 or 5 in the morning for no one, is absurd.
Honorary Tony Oldest to youngest 1971 ZD Fairlane 1978 W123 Mercedes Benz 280e 2004 BA XR8 2007 W211 E63 ////AMG 2008 Fiat Ritmo -for the kids to take ownership of while I pay for running costs 2009 SYii Territory Ts now the kids swapped with below 2011 W212 Mercedes Benz E350 now the wife’s swapped with above |
2 users like this post: |
#20 | ||
Cars are their most efficient at highway speeds.
The biggest reduction in emissions can be achieved by pinging off all the bike and bus lanes and opening the roads to cars. If you don't have to stop/start a millions times crawling a few kilometers down the road then this technology is redundant.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
#21 | ||
![]() Join Date: Dec 2006
I am not a fan of it and usually turn it off or go into sports mode to kill it.
But once I was in a 10 mile 45 minute traffic jam in LA and thought I will let it do its thing...as said above if the battery got too flat, or you wanted the a/c colder the engine would NOT shut off so that was reassuring to know. |
#22 | ||
Well I hate Baby Fur Seals, so they can go **** emselves
#23 | ||
The one thing it does that just really ****es me off quite irrationally, is that when you pull up somewhere to park, it switches off. But then starts again when you put it into park. And if I remember to kill it before changing gear, ten it screams at me to put the selector into park.
#24 | |||
#25 | |||
I believe that it is probably a complex way to to meet an emission regulation parameter, ie, to pass the test - then we are stuck with it. My experience was a rental Astra in UK for 3 weeks, manual trans. It caught me out a few times (did not restart when I hit the accelerator on a green light - had to hit the ignition key quickly), before I worked out how it worked. On some rural intersections with traffic lights that were going to run for a while, I was putting it in neutral with handbrake on (that's ok, isn't it?), then taking off without touching the brake pedal - normal driving in my book. So I concluded it was restarting based on release of brake pedal, not pressing of accelerator. Stupid, poor design. My wife felt very uncomfortable every time it gave the little "I'm stopping" shudder. I didn't have time to find out how to disable it, but it didn't worry me that much. I was in quite a long traffic jam on a motorway in the middle of nowhere, for about 10 miles, and was wondering how the battery would last - in a post above someone has said they won't stop if the battery is getting low - makes sense - as does the air conditioning "exemption". Cheers.
1967 XR 289 V8 Falcon (1st) - 1973 XLE 250 4spd Cortina (2nd) 1987 XF GL 4.1 Dual-Fuel Falcon (3rd) - 1996 EF 4.0 GLI Falcon (4th) 2003 BA 4.0 LPG Falcon Wagon (5th) 2016 SZ Territory TX 4.0 Petrol (6th & last?)(Sadly, written off) 2004 WRX (Retirement Toy) |
#26 | |||
As for the post above saying it’s good for traffic jams in places like LA. It’s not really. In those sorts of traffic jams you usually only stop for a few seconds at a time before rolling forward at 10kmh or so. Auto stops only good for traffic lights around town when you have to wait for the full sequence |
#27 | ||
praek tih kl jo kr
Have it on our C200 and Smart Fortwo, on the Smart I made up a board that sends a signal at start up to disable, If I want it on I have to press the Eco start / stop button
Dont know if it could be adapted to others but here is the link I used https://www.evilution.co.uk/electric...f_at_start.htm |
#28 | |||
https://www.greenvehicleguide.gov.au...nsumptionLabel , here you can see what test cycles are . Last edited by SumoDog68; 14-09-2020 at 12:33 PM. |
#29 | |||
#30 | ||
T3/Sprint8
![]() Join Date: Jan 2005
Seems the CX5 is popular that it is.
Wife's one has it, I hardly use it so wont bother de activating it and the bimmer has it, couldn't give a toss about it tbh, leave it as it is.
