Old 17-09-2020, 11:17 AM   #1
ford12
Default AU severe vibration
Hello All
Wandering if anyone has some advice.
Every now and then ( Maybe a couple times a week ) I get a bad vibration that feels like its coming from the front left hand side of the car.
Could this be the wheel bearings ?
If so does anyone know of a good place to buy them, Ford want $165 each.
Thanks in advance
PS. I know this is posted in the wrong section, but it seems if you want a quick reply, the pub section is the best way to go
ford12 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2020, 11:59 AM   #2
gutza
Default Re: AU severe vibration
Hi ford.
When does this happen ......
When turning ?
Or just on a straight, relatively smooth road ?
Cheers.
gutza is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2020, 12:13 PM   #3
GasoLane
Former BTIKD
GasoLane's Avatar
I'd be taking it to a wheel alignment place............NOT a tyre dealer though.
Old 17-09-2020, 12:21 PM   #4
ford12
Originally Posted by gutza View Post
Hi ford.
When turning ?
Cheers.
Hey Gutza
Happens on a straight relatively smooth road - only does it for a second or two.
I should have also said I did notice a not quite a grinding or rubbing noise more like a Whirring noise when turning Right at a very slow speed - in a car park
Old 17-09-2020, 12:49 PM   #5
gutza
Hi ford.
Just a couple of easy checks.
1. Make sure all lug nuts are done up close to spec, especially alloys. You may need a torque wrench. 21mm socket, I think.
2. Use wheel changing jack, get wheel off the ground. DO NOT GET UNDER THE CAR with just this.
3. Grab wheel at 12 & 6 o'clock. Rock back and forth. Any movement could be wheel bearing.
4. Grab wheel at 9 and 3, and rock. Any movement could be Tie Rod End.
5. The 'whirring' is interesting. Check PS fluid level.
Cheers.
