22-12-2020, 11:56 AM | #1 | ||
I was trying to fix a magnetic phone holder to my FG dash and in a moment of fookin stupidity and anger cause the 3m stuff wasnt working, I used Araldite 5 Minute Epoxy Adhesive
Only then to realise that the bleedin holder wouldnt hold the phone because of the rugged case I need,. Ive solvered that......... but left with a fookin mess on the dash between ICC and cluster how do I remove it PLEASE
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
22-12-2020, 12:06 PM | #2 | ||
Trusted Seller
try heat, a plastic chisel to scrape off, but the heat may stuff up other stuff.
i know that araldite is pretty strong |
22-12-2020, 12:12 PM | #3 | ||
Trusted Seller
is that the soft bit of trim around the cluster that's all messy? if so what happens if you depress it, maybe it will crack the araldite off....
22-12-2020, 07:55 PM | #5 | ||
thanks guys, paint stripper eh? who would have guessed. I will be doing it sparingly.
22-12-2020, 11:36 PM | #6 | ||
Excessive Fuel Ingestion
Yep, be very careful, good chance you could melt the dash perhaps.
Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay), |
22-12-2020, 11:46 PM | #7 | ||
Ah yes, that was the small detail I held back. Methylene chloride will write off the dash pad while removing the epoxy. Don’t use it.
My honest personal choice would be WD-40 or similar sprayed liberally onto a rag and worked over, it will creep between the dash skin and the adhesive. Slow, maybe very slow, but not harmful. 5 minute Araldite is revolting stuff at the best of times. |
22-12-2020, 11:52 PM | #8 | ||
23-12-2020, 09:17 AM | #9 | ||
HOW DO I REMOVE CURED RESIDUES OF ARALDITE ?
For Araldite Super Glue: residues can be removed using warm water and soap water. For Araldite Epoxy adhesives: Cured residue or exuded adhesive may be destroyed by immersion in commercial paint strippers, such as Nitromors or Multistrip, and these are available from most retail paint suppliers. Joints may be broken by soaking in these chemicals for periods up to 24 hours depending on the joint width and thickness. Details for use and safe handling of paint strippers should be obtained from the manufacturers. NOTE : Care should be taken in using the chemicals given above since they may be hazardous to handle or inflammable, and may also attack the substrate. my concern was this could be OK on hard surfaces, but the ole dash is not hard. think I will try Citroënbender second idea, just hope he has not forgotten something else
23-12-2020, 10:08 AM | #10 | ||
No, no other omissions.
As that document concurs, paint stripper will shift epoxy but you’d choose your substrate to not include vinyl polymers. The WD-40 “trick” I learned from a musical instrument restorer in Sydney who'd diligently shift amateur-applied substances from a maker’s original surfaces in this way. But, rag it in; never spray directly. |
23-12-2020, 01:21 PM | #11 | |||
The good, bad and fugly
Time was on my side! |
23-12-2020, 01:26 PM | #12 | ||
60 ....60 degrees Celsius yes God's I hope not.but again thanks for heads up.
