Hello
I bought a 250 crossflow 6 from a wreckers a couple of months back which i have put in a boat , it came with an electronic Distributor and no coil, the wires where cut from the coil. so what I'm left with brown brown/black yellow/green I'm guessing the Brown is + and the brown /black is _ not to sure what the yellow/green is can someone please give some advise cheers Garry |
around the place
is it sn XF EST distributor? post up a pic of what you have....
GPS Tracker for your vehicle - PM me for info |
Hi Coupe
same as this one as attached cheers Garry |
As far as I can see from those pics, that dissy is an XF EST unit & as such doesn't do much on its own. It is meant to be used with an EST control module (ECU). All it has inside is a hall effect pick-up & no method of advance.
For your boat motor you need a proper electronic dissy out of an alloy head XD, an XE or a leaded XF (pre-1986). It is a complete dissy with full advance mechanism & control module, it just needs an ignition coil & you are right to go. Dr Terry. |
Thanks Doc
that's all i needed to hear lol ....more money god dam it cheers Garry |
#7 | |||
Dr Terry |
Thanks Doc
appreciate the advise given cheers Garry |
around the place
mate just be careful with those chinese ebay cr@p ones. you will either have issues with the module failing, or the gear chomping the cam.. its very common especially on the singlecam engines cheap dissy costs engines after a few months.
personally id get onto a ford wrecker and see if theres any genuine bosch/motorcraft ones around and get hold of one and rebuild it if needed. I probably had a box full of them, but got rid of all the junk that never got used :(
