The hatch door switch has failed and feels like the button is stuck. The remote will still unlock the hatch and the reversing camera is still working.
After removing the hatch door interior trim there appears to be no access to this switch. It appears that this switch / camera assembly just clips into place without screws. Is someone able to advise the method of removing this item? |
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
It's probably not a lot of help but the only instructions in the WSM is the diagram below:
Observatio Facta Rotae
#3 | |||
Hopefully this link has the info you're after. CLICK HERE
Current: 2016 Camry 1966 Mustang Coupe Previous: 2011 SZ Territory Titanium 2008 Ford Edge AWD Limited Silhouette BF XR6, ZF Auto White EF GLi, XR look alike VH Commodore |
#4 | |||
Thanks. I'll take the interior trim off again and have another look at this. |
To close off this thread.
I was able to see the right end retaining clip with the interior panel removed. Once pressure was applied the switch assembly was released and then all was required was the disconnection of the 2 wiring plugs. Thanks. |
