06-01-2022, 04:15 PM | #1 | ||
el runs on gas wont run on fuel. fuel pump runs & full tank
06-01-2022, 04:20 PM | #2 | ||
06-01-2022, 04:58 PM | #3 | ||
are the injectors getting a pulse ?
can pick up a pulse lame real cheap and unplug an injector and plug in the diode lamp to see if injectors are getting pulse think i paid under $20 for mine and turned out to be the problem , then had to work out where and why they wernt getting the pulse from the ecu , think it was a bad connection some where but cant remember as was quit a few years back
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
06-01-2022, 06:03 PM | #4 | ||
could also be a fuel blockage and/or bypass valve stuck open so rail isnt getting pressure to the injectors
07-01-2022, 07:59 PM | #5 | ||
Custom user title
Just check you have 12v at the injectors when running on petrol. Used to cut the power on gas. . Most likely wire has been knocked of the relay check the loom, most likely spliced near the idle speed control solenoid ( as this needs 12v on both fuel and gas)
