26-01-2023, 07:59 PM | #1 | ||
Hello all.
Can I get some advice from the people in the know. I bought a vacuum brake bleeder in the hope it would make it much easier to do. I can not get it to work. It holds vacuum and easily empties a container of brake fluid in no time. Problem is it will not suck brake fluid from the bleed nipple, the most I can get out is a couple of drops. What the hell am I doing wrong ? Car is a FG mk11 6 cylinder ute. Last edited by ford12; 26-01-2023 at 08:20 PM. |
26-01-2023, 08:35 PM | #2 | ||
I'm wondering if the bleeder nipple might be blocked with crud Ford12?
26-01-2023, 08:47 PM | #3 | ||
26-01-2023, 09:39 PM | #4 | ||
Sure you got enough pressure?
They generally need around 100psi.
26-01-2023, 11:24 PM | #5 | ||
Is this one of those ones that connect to a air compressor?
I bought one too, it sucks balls and doesn't do squat. It sits in the corner gathering dust now. |
27-01-2023, 09:05 AM | #6 | ||
Hi. try doing it with the lid off the master cyl. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
28-01-2023, 11:19 AM | #7 | ||
I bought a reasonably cheap one from Sydney Tools and it works fine - WITHOUT the brake pedal being pushed
https://sydneytools.com.au/product/d...e-bleeding-kit |
28-01-2023, 12:32 PM | #8 | |||
I must be doing something wrong. |
28-01-2023, 12:33 PM | #9 | ||
28-01-2023, 01:34 PM | #10 | |||
Usually it sucks around the threads on the bleeder nipple, try only opening it 1/4 of a turn. or Try gravity bleeding, open the nipple place a catch container under, make sure master cylinder is full and go and make a cup of coffee or tea. Check the master cylinder fluid level and top up once per wheel. Make a cup between each wheel and remember to go when needed. Sure it's slow, but we found with the race cars it was the only way to guarantee a complete bleed (apparently drivers don't appreciate coming to the 1st corner and finding no brakes, go figure) Stay safe Terry aka Tbro |
28-01-2023, 04:36 PM | #11 | |||
I second this Method, Sure It's time consuming But, It works.. |
04-02-2023, 10:45 PM | #12 | ||
Vacuum bleeders work well in dealer situations where time is critical to do multiple operations. Pumping fluid via the pedal is the best. although requiring more people to accomplish.
05-02-2023, 09:42 PM | #13 | ||
I wonder if it has something to do with the ABS system
06-02-2023, 07:10 AM | #14 | ||
ABS is electronic not hydraulic
ABS is an over-ride system and only works when your foot is firmly planted on the brake pedal with the car running |
06-02-2023, 09:25 AM | #15 | |||
I love Holdens.... |
06-02-2023, 02:58 PM | #16 | ||
