Old 23-06-2005, 05:46 PM   #1
Ay-You-Steve
Ay-You-Steve's Avatar
Question Condensation in Headlight
I've got some serious Condensation in my AUI F'mont L headlight. First thing is to wipe it dry, so how do I take the h'light cover off ?, and do I just have to replace the rubber seal providing there are no cracks ? (can't see any).
Cheers :
Ay-You-Steve is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 07:59 PM   #2
Duffman
Oh Yeah!
If its inside the headlight you need to heatup the silcon to pop it open. Either a oven or a heat gun. Then reseal it.
Duffman is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 08:04 PM   #3
Ay-You-Steve
Yep its inside, thanks.
Old 23-06-2005, 08:11 PM   #4
The Dok
The Dok's Avatar
Cheers :
:Up_to_som Another common problem with AU headlights. Unless your'e real keen l wouldn't advise putting it in an oven etc. It has no rubber seal, it's actually "bonded" in place much like modern windscreens. Pm me if you like & l can give you some options!!!
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 10:47 PM   #5
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
If you only want to get rid of the condensation, the simplest way is to take the main globe out and stick a hair dryer in there for 1/2 an hour or so (saves taking the head light out of the car)
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 11:21 PM   #6
The Dok
The Dok's Avatar
Band aid solution. "SERIOUS" condensation means there's water coming in somewhere. Good luck gettin a "hairdryer" in behind the RH headlight, can barely get my bloody hand in to change the globes!!! :
Removed by laminge
Old 24-06-2005, 12:00 AM   #7
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Thats why it takes half an hour instead of a couple of minutes :
I did this in my EA when I bought it and there hasn't been any condensation since.
Daily driver
Other
13.75 @ 101mph
Old 24-06-2005, 12:11 AM   #8
LUXO_8
windsor user
ahhahaha.... dodgy!
AU headlights are notoriously bad for leaking, its common knowledge around the auto industry that ford sent out a memo to taxi owners not to use a highpreasure washer to wash their cars with because the headlights leak...
however, its kindof easily fixed... well for me and doc it would be anyway..
the headlight needs to be dismantled, no doubt about it...
then new sealant used in the chanel, then the lens re-aplied.
Old 24-06-2005, 02:37 AM   #9
JC
JC's Avatar
There's a tech article on aufalcon . com that describes how to remove the headlight from the car, and then how to pull it apart (and yes, it does involve an oven). While you're drying it you might as well paint the bezels black.
Ford Performance Club ACT
Old 24-06-2005, 10:09 PM   #10
Ay-You-Steve
MY downfall right there.... : I'll stick to the bucket in the back yard.... :
Old 24-06-2005, 10:53 PM   #11
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
Had this happen with my BA, I just took out the High beam globe and drove around with my headlights on for the day. The heat dried it out very well and when I put the globe back in it never came back.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2005, 11:22 PM   #12
The Dok
The Dok's Avatar
e Happened to me too (RH side) as l too use a pressure washer to wash my car, (was LAW in melb). Early indications (pardon the pun) seem to say, just like the AU, the BA's will suffer the same water pressure seal weakness, although it shouldn't happen!!! Could be worse though, on my EF, above RH headlight is the bonnet alarm pressure switch, hit that with the pressure washer & it's a great way to test the headlights, indicators, siren & the neighbours patience, all at the same time!!! :
Removed by laminge
