09-07-2005, 03:37 PM | #1 | ||
Gday peoples
Lately I've been having a few dramas with the computer being a bit of a pig to start up....bit like an old car on a cold morning and a dodgy carby Turn the PC on, sometimes while the hard drive cranks over the monitor wont switch on from standby. Usually it happens when it's cold for some reason, sometimes you have to reset it 4 or 5 times to get it to turn on. When it does turn on, it freezes at random points..... either at the loadup screen (right after you turn the machine on), when the windows logo comes up, at login, or at the Windows XP desktop. Mouse freezes and you have to reset as cntr-alt-del wont work Once it has fully loaded however, the internet is connected, there are no issues whatsoever. I'm thinking it could be the operating system not starting correctly or hardware has trouble feeding power or something continuously.... Hardware details: Pentium(R) 4 CPU 2.40GHz 256MB RAM Cheers |
09-07-2005, 03:42 PM | #2 | ||
Something might be wrong with the RAM.
09-07-2005, 03:46 PM | #3 | ||
Custom User Title
Yup, I would suggest corrupted RAM, however I was having problems similar to this (But not as severe) and it turned out that my CPU was not seated in the socket the whole way. How many Sticks of RAM do you have? If you only have one, then you might have to borrow some, however if you have two or more sticks, try turning the system on with only one of the sticks. If the system runs fine then you know it's one of the other sticks, however if they all do it then you're looking at a different problem. The fact that once it starts it starts fine also leads me to belive that it may be the PSU...
09-07-2005, 03:50 PM | #4 | ||
Not sure on the sticks...it originally had less RAM (forgot the figure) and got it updated probably 2 years ago so he may of added some higher MB into the slots
I will take the cover off later and have a gander at the internals...could be just one of those things that wear out over time. |
09-07-2005, 03:54 PM | #5 | ||
Custom User Title
Might be a good idea to clean out all the dust that accumulates in there over the years while you're at it.
09-07-2005, 04:29 PM | #6 | ||
Cobblers!
Get a Can of Air from Dick Smith and spray the computer out. Spend a greater amount of time on the fans and CPU than anything else. Also, Re-seat the RAM, and then do a Defrag on the HDD. That should help speed the computer up.
-Andrew
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
09-07-2005, 04:38 PM | #7 | |||
09-07-2005, 04:41 PM | #8 | ||
Custom User Title
Not much, but I wouldn't bother...I just use a vacuum cleaner, but be careful not to hit anything with the nozzle. Also might want to be weary of static electricity when you're doing it
09-07-2005, 04:44 PM | #9 | ||
do you have hard drives in a raid configuration?
09-07-2005, 05:02 PM | #10 | |||
Foo Fighter
09-07-2005, 05:12 PM | #11 | ||
download memtest 86, you create a floppy with it that you boot off and it runs a diagnostic on the ram. http://www.memtest86.com
09-07-2005, 06:59 PM | #12 | ||
How do you use that memtest...i have downloaded it but the instructions on the website and readme file are pretty vague
09-07-2005, 07:01 PM | #13 | ||
Foo Fighter
I had to use that too, takes frickin ages, I used it on a CD because I dont have a floppy disk drive, cant remember what I did now sorry.
09-07-2005, 09:05 PM | #14 | |||
09-07-2005, 11:19 PM | #15 | ||
Tried the memtest found no errors...i'll give the insides a clean tomorrow and see if theres any crap in there
09-07-2005, 11:36 PM | #16 | ||
Custom User Title
It's the PSU then, lucky, they are nowhere near as expensive as RAM...
10-07-2005, 09:43 AM | #17 | ||
Regular Schmuck
Software memtesters aren't the be all end all, in fact I wouldn't trust it to find anything but an obvious problem. Once you're at the point of running memtest, your PC seems stable so if it was a mem issue, you'd likely get 3 long beeps at POST when it couldn't boot and your PC wouldn't be stable once it was up and running considering it's such a small amount of mem.
Unless you have a can of air, I wouldn't rummage around the innards of your PC either, I'd only even use the can of air in small doses to blow off large deposits of gunk away. I've seen servers covered in a 2 inch layer of coal dust and still work fine. While dust minimises the effectiveness of components to dissapate heat, it's unlikely it's causing this issue. Need a lot more information to make a reasonable edumacated guess. When you first turn it on, do you hear a sequence of beeps, do the LED's on the keyboard flash? If you do hear beeps then it's your system board giving you an audible indication of why it believes it can't POST. If it doesn't beep, could be sys board, PS or proc issue. (I've seen proc's pop out of sockets when they're hot, but not when they're cold and I could count on one hand how many proc's I've replaced due to a legitemate issue on one hand in fifteen years) When it locks up mid boot, does it write an event out to the system log? If you don't have any gear to prevent ESD (reasonable static strap), I wouldn't take the cover off, particularly if you have warranty on the box. This sort of issue is a classic symptom of a component damaged by ESD in the first place. |
10-07-2005, 02:20 PM | #18 | ||
Custom User Title
You don't need an Anti-Static wrist strap, just make sure you ground yourself by touching the case before you get to work. Also, the best way to solve hardware problems is to use trial and error...Go ahead and rip it apart, unless you're stupid about it, you'll be fine.
10-07-2005, 02:35 PM | #19 | ||
LPG > You
If you want to see if the RAM is at fault, try playing Solitaire. It is the most RAM sensitive application Windows has, and is renouned for going pear shaped with the slightest issue with your RAM. If it works fine, that's not the issue.
Personally, I'd see this as an opportunity for a decent upgrade... Throw out the P4, its mobo and the 256 stick of RAM... get an Athlon64, 1GB of DDR400, a good Skt939 m/b with PCI Express (like an Asus A8N-E), an decent PSU (like an Antec TruePower 430W) and you've got it made. But yeah, sounds like it could be either the RAM, motherboard, CPU or Power Supply being dodgy.. though I'd blame it on the first three before considering the PSU.
LPG Lovers Association President & Member #1. : |
10-07-2005, 03:18 PM | #20 | |||
Regular Schmuck
The best way to solve hardware problems is to diagnose the fault using all the information available then taking the most likely path. Unlike myself, I doubt the OP has a warehouse full of parts he can use to go down the 'trial and error path'. I know if I took that path I'd be out of a job. |
10-07-2005, 04:14 PM | #21 | |||
10-07-2005, 04:26 PM | #22 | |||
There is alot to do before proclaiming the CPU is the issue and throwing it out. Ive had the exact same issues occur due to USB printers being hooked up during bootup. My advice, disconnect all peripherals first, printers, usb devices, scanners, anything, id even test out different mice and keyboards if you have access to them. Then see if the problem reoccurs on boot up. Chances are this is a compound problem rather then one single cause.
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
10-07-2005, 05:18 PM | #23 | ||
Custom User Title
Oh come on. It has problems starting up, but once it is going, it runs fine. The power supply is not supplying enough power, hence the system is not starting up as stable as it should, because during the POST every component of the system is switched on, hence why it is called a POST, it tests everything. If it was the CPU, you'd have constant stability problems. At first I suggested the RAM, but that was because I hadn't read the question throughly. As for the static wrist strap, if you feel there is a danger, by all means use one, but I never have and i've never had a problem.
10-07-2005, 05:34 PM | #24 | |||
10-07-2005, 05:39 PM | #25 | |||
beep beep
If you put a ohm meter between the alligator clip and the wrist strap you will find a resistance of about 1Meg Ohm.
Nothing to see here, move along, move along... |
10-07-2005, 05:47 PM | #26 | |||
Regular Schmuck
Firstly, there are many reasons why a PC won't POST and very few of them have anything to do with the supply of voltage on the rail. Secondly, POST doesn't test everything. In fact it barely tests anything. A POST is a very rudimentary test for a PC's ability to boot a ROM. There are many combinations of failures that equiment can have that will past POST at boot. It would appear you still haven't read the question thoroughly because once it's going it still isn't fine innitially. Try reading the question again. Lastly, because you've experienced no problems with ESD does not mean it isn't a problem. In fact, that's the biggest problem with an ESD failure... most of the time it isn't a hard failure but a latent defect. As part of ISO9000 certification, I'm required to sit through a boring environmental course on ESD packaging, handing and procedure every 6 months (for the past 15 years). Once a month I have to submit my straps and mats for testing. I've seen the effects of ESD under a microscope (it's part of the course) the surface of the IC is reasonably flat until it's touched by a finger at a higher static potential, then the IC looks like a crater on the moon. The same IC is on a board and will happily past POST, however, it has a largely diminished capacity (latent defect). The company I work for estimates losses of about $600 million a year due to inadequate handling of static sensetive components. The equipment I work on is what keeps multinational companies running. If I was to walk up to a non-stop server, touch the case then start working on it, I'd be lucky if I wasn't fired on the spot. If I was to incorrectly handle a component that has been removed from a server and is proven to have failed, I still risk instant dismissal. http://www.esda.org/esd_fundamentals.html I suggest you read the above. |
10-07-2005, 05:50 PM | #27 | |||
Regular Schmuck
10-07-2005, 06:06 PM | #28 | |||
Custom User Title
10-07-2005, 06:11 PM | #29 | |||
Regular Schmuck
Read the link I provided. You may actually learn something. |
10-07-2005, 06:11 PM | #30 | |||
Thanks Rod and others for the help in this thread I ran the memtest again today, for nearly 6 hrs while I was out, and it did 50 passes and found no faults. However, when it just kept going and not stopping I just tried some of the options. One of them I tried was an error report on Bad RAM sectors, where it listed 1000's of errors.... confusing.... As what you said about the dirt not affecting much inside the box, a few months back i had a dvd burner installed and some errors fixed (hard drive wiped by service pack 2)and it would most likely have been cleaned back then The good thing is though, today there are that many people who know their way around a computer and parts can be bought so much cheaper, that upgrades can be done for a few $100 instead of over a grand. I just hope by the time I upgrade it's not crashed again as today we signed up for adsl which should start in a few weeks! |
