Old 01-08-2005, 10:25 AM   #1
3Inch5.oLtr
xr8 ute
Arrow au amp upgrade
does any one know if you can change the amp in a fairmont ghia to a higher powered one i have a au f g 111 with sat nav 5.0 lt thanks.
3Inch5.oLtr is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2005, 01:09 PM   #2
blackers10
blackers10's Avatar
u cant
the standard headunit doesnt have RCAs poking out the back
but has RCAs going INTO teh stock amp..
the RCAs will produce NO noise from an aftermarket amp..(tried that)
you wil need your self a new headunit .. and all the wiring required to put a new amp in...(RCAs..power.. ground..remote cable) then yeah..
if you disconnect the standard amp.. the standard sub and both standard rears will stop working even when connected to the aftermarket headunit.. its wierd..
hope i helped
Old 02-08-2005, 01:21 AM   #3
3Inch5.oLtr
xr8 ute
ok thanks ill stick with what ive got,.,.,.,.//.,
Old 02-08-2005, 07:09 AM   #4
vbtruk
vbtruk's Avatar
acttually you can i have done it in mine and the whole idea was to keep my factory HU cos i like the 6 disc in dash feature.
AU III Fairmont Ghia
All you need is a little thing called a Stinger line level converter and the new amp thats it. And make sure to buy the stinger ones they are the best and i have three in my car.
vbtruk is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2005, 09:53 AM   #5
phildee
phildee's Avatar
I would presume you could also use an amp that has speaker level input if you dont want to spend too much.
Cheers, Phil
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2005, 06:05 PM   #6
vbtruk
vbtruk's Avatar
Not sure as i bought Kicker amps and tried using the speaker hi level input plugs it had and the signal of the stock system did not match so therefore it had to be line level converters. here is the thread we had on it: http://www.fordforums.com.au/showthread.php?t=2677
Old 02-08-2005, 09:33 PM   #7
Stav
Smile
Stav's Avatar
Dont muck around mate.You can get rca adapters which get connected toexisting speaker wires and convert to low level rca comaptible sound.
Old 03-08-2005, 05:43 PM   #8
vbtruk
vbtruk's Avatar
Yeah that's what we are talking about they are called Line Level converters and the good ones boost the signal to give a clearer sound as an aftermarket HU would.
Old 03-08-2005, 10:27 PM   #9
Stav
Smile
Stav's Avatar
Thats great if they do that..but depends on thd(total harmonic distortion.) of the components really.
