Old 05-08-2005, 06:59 PM   #1
chief
FTF Club Moderator
chief's Avatar
Default Power window reciever switch?
My power window on my AUII for the front passangers side does not go up or down. Lucky it is stuck up though : A frind of mine was sick in the car about 14 months ago, i poured buckets of water down the door (Yes i know heinsight can be a pain in the ***) to flush it out. 3am is not when I want to be detailing the car. The problem started about two weeks ago and anyway the window will not go up or down from both the passangers switch and drivers switch. I believe it could be the reciver switch that inieates the actuators to make the window go up and down may be gone.
How do you remove the front passangers interior door trim? To look at the reciever switch if it is there. How do you fix this problem.
Albert Einstein:
Fords in the Park 2010
Old 05-08-2005, 09:28 PM   #2
Stav
Smile
Stav's Avatar
Look ast your switches in the drivers door first.That panel with the switches come up and off.Check it for coke spills or corosion.Sometimes the drivers door switch wirng harness comes loose and the passengers side stops working.
Old 05-08-2005, 09:58 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
Pull the panel useless described off.. Pry it out of the arm rest with a flat blade screw driver.. Undo both switches and swap the wiring looms around as to check if you can put the passenger up and down using your working drivers switch.. Also using your good switch put that into the passenger side and try it there aswell as if one switch fails the 'master' switch on the drivers side won't operate the window
If it starts to work OK with the good switch, you can easily pull the other switches apart and clean out any crap and freshen the contact strips inside the switch with the screw driver.
Old 06-08-2005, 11:30 AM   #4
chief
FTF Club Moderator
chief's Avatar
Thanks Useleess and Tibbo. I am going to do that today and I will post on a result.
Albert Einstein:
Old 06-08-2005, 11:34 AM   #5
aquahead2001
aquahead2001's Avatar
Had the same problem with our AUII Fairmont wagon, except the window was down!
Pulled the entire door apart to check if the electric motor had gone kaput only to put it all back together again to find it working....
There was the slightest bit of corrosion on the blades coming out of the back of the door control switch. Nothing would work until I cleaned it up with a little bit of emery paper.
The little panel it sits on comes out very easily with a flat blade. Shouldn't take you more than 10 minutes to fix!
Cheers!
aquahead2001 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2005, 12:44 PM   #6
GlennBA
GlennBA's Avatar
I had a similar problem in my AU, the passenger window would only wind up. It would wind up and down via the drivers switch. I took the switch apart and used an emry board (thanks mum lol) to clean it up a bit and its working now.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2005, 01:27 PM   #7
blackers10
blackers10's Avatar
i think this is a SUPER COMMON RECCURING AU problem.. aka the window switches crapping out due to corrosion of the contacts..
as mine has done it twice since i got it..
and thats only like 3 months
Old 06-08-2005, 07:00 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
I did a quick tutorial up if you need images to explain it better
http://www.fordforums.com.au/showthr...828#post263828
Old 06-08-2005, 07:36 PM   #9
chief
FTF Club Moderator
chief's Avatar
Thats a great tutorial Tibbo. I can hear myself walking out the door now to try this.
Door closes
Albert Einstein:
Old 07-08-2005, 09:38 PM   #10
chief
FTF Club Moderator
chief's Avatar
SUCCESS!!!
Tibbo - Thank you very much for tutorial. Yes this did solve the problem. It is amazing how much stuff built up on the contacts.
Albert Einstein:
