Old 20-01-2005, 08:12 PM   #1
XRQTOR
XRQTOR's Avatar
Default Lcd or Plasma screen.
Hey fella's, bit of a teck question here so i hope someone can help. Im looking at adding a larger Flat screen to my computer, currently have a 15'' screen and was looking at possibly 23. But browsing ebay i have noticed plasma screens are getting cheap, can i hook up a plasma screen or lcd screen to my computer and run the pc like normal with a massive screen or isn't it that simple. And can i still use it as a normal tv.
Old 20-01-2005, 08:35 PM   #2
XplosiveR6
Viper FG XR6 Turbo
XplosiveR6's Avatar
yea sure you can plug a plasma into ur pc via the the DVI port (thats if you have a DVI port on your graphics card)
XplosiveR6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 08:38 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
Plasma is the way to it will have PC input, but check for built in TV tuner, or you will need a set top box, if the plasma is any good it will have multi phasing or something like that, it means they have 3 pixles (pretty sure) per plasma dot and cycle through at such a high rate you cant see it, but it stops burn in like the old plasma screens.
Old 20-01-2005, 08:39 PM   #4
XRQTOR
XRQTOR's Avatar
Shrugs, i dunno. What i want to try to do is get a wirless keyboard & mouse and a big **** screen.
Old 20-01-2005, 08:45 PM   #5
XplosiveR6
Viper FG XR6 Turbo
XplosiveR6's Avatar
its a much better idea then those media pc's that you buy at the store with ****y 15inch screens, i mean who is going to watch movies and tv on a little 15inch computer lcd
Old 20-01-2005, 08:58 PM   #6
Paris Hilton
Custom User Title
Paris Hilton's Avatar
Apple Cinema Displays are unbelievable. So crisp, clear...easy to set up, easy to watch, only problem is that you pay for it :\
Paris Hilton is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 09:05 PM   #7
champsky
THCC Motorsport member 1
champsky's Avatar
hey, would you be bale to do it on a rear projection???
my bro has a 151cm RPTV and thought it might be cool to hook ya pc up to it hehehehe, would be kinda cool aye :P
Southcyde Designs<------click here :
Member of the MTAS
Founder of TTM (team twink motorsport)
Founder of the AFFDDPS (Australian Ford Forums Drink Driving Punishment Squad)
champsky is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 09:14 PM   #8
EA2BA
PM me if you want
EA2BA's Avatar
Get a TV output card champsky, only problem is, the bigger the TV the crappier the TV picture, but with the huge screen resolution possible these days from video cards it may not display too bad.
Old 20-01-2005, 09:22 PM   #9
Peuty
Afterburner + skids =
Peuty's Avatar
Nope, the rear pro will not provide adequate picture imo. Remember, even though your graphics card may be high res, the rear pro can only project what it is capable of. Unless it is a high res unit, which most are not.
Its the same as hooking a computer up to a regular TV, crappy, crappy picture, simply because of the low res TV output.
Oo\===/oO
Old 20-01-2005, 09:26 PM   #10
XRQTOR
XRQTOR's Avatar
Our big 144cm rear projection tv has a tv connection, never used it. Instead of using the normal lcd screen u just hook up the rear projector.
Old 20-01-2005, 09:38 PM   #11
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
Plasma screens, from what i understand, are not good up close and can only run at a maximun of 800 x 600.
LCD's on the other hand (or tft or whatever they are) are born for a specific resolution in mind (usually 1024 x 768) and are crystal clear only in that specific resolution.
Therefore, if you were going to use the computer as a normal computer, I'd go the LCD screen (although that would be very expensive for the size your looking at).
Options, Options..
Black 1990 300zx Twin Turbo 5 Speed Manual :
Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. :
BlueRaven is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 09:42 PM   #12
Firefox7
T3 Terrorist
Firefox7's Avatar
You would be far better off with an LCD screen. Plasma Screens only last for around 7 years or less depending on the manufacter. Lcd on the other hand will last double to triple. If the backlight in the LCD fails it can be replaced. Once the brightness in a Plasma begins to dim...their is no recovery, you throw it away.
Proud Owner of a Tickford TE-50 T3 No 033...13.16@107.12 mph 1.868 60"
Fastest Lap time At wakefield park on Dunlop Sp9000's : 1:14:30, Came 2nd in outright driver, in the overall V8 result, 2006 N.S.W dutton rally :1syellow1
:king: T3 :king: The Mightiest & Deadliest Tickford Ever To Hit The Road........
Firefox7 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 09:43 PM   #13
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
Or converted to a DIY Projector screen like this
http://www6.tomshardware.com/howto/20041113/
Old 20-01-2005, 09:44 PM   #14
Peuty
Peuty's Avatar
But if you have a few dots fail on the LCD, same thing....hello bin.
Horses for courses.
Oo\===/oO
Old 20-01-2005, 09:48 PM   #15
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
I'd be surprised if plasma screens are built in any quantity in 5 years time. LCD is the future. That being said go for screens being sold in bulk, ie ones available at most PC/Electronics stores. They offer the best bang-for-buck. 17inch screens represent good value atm.
19 and above, particularly widescreen will be expensive. The most important thing to look for (apart from dead pixles) is response time, 12ms is what you need.
If you've got a fat wallet then ignore what I've just written.
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 09:51 PM   #16
Firefox7
T3 Terrorist
Firefox7's Avatar
Already got a projector....I have used it for the pc a few times, especially good flight simming with it....My screen size 4 metres x 2 metres for games in 16:9. It has the best picture that i have seen in any projector....very clear and bright but the colours are outa this world.
Cheers.
Old 20-01-2005, 10:39 PM   #17
XRQTOR
XRQTOR's Avatar
http://cgi.ebay.com.au/ws/eBayISAPI....745606895&rd=1
This one is cheap as shit, big as hell to.
Old 20-01-2005, 11:07 PM   #18
b2tf
not here much anymore
b2tf's Avatar
This reminds me.
I was very interested in getting a plasma screen TV a while ago, but i remember a salesman telling me they have a lifespan of about 5000 hours before they just turn to crap. 5000 isnt really that much when you're paying $3k or so for a TV, so i didnt buy one.
But is it true?
2024 F150 XLT
Old 20-01-2005, 11:09 PM   #19
Peuty
Peuty's Avatar
Yeah, pretty much. As mentioned before, the plasma tends to go dull, then duller, then dullest.
Oo\===/oO
Old 20-01-2005, 11:20 PM   #20
champsky
champsky's Avatar
does that include brand new ones, cause my bro got it like a month or two back.
Member of the MTAS
Old 21-01-2005, 11:35 AM   #21
rag top
rag top's Avatar
Originally Posted by back2thefutura
This reminds me.
But is it true?
I've heard a rumour about 8000 hours life span of plasma screens... :
I don't believe it either.
At work, we run 2 plasma screens, 24/7 for over 2 years. That is at least 17000 hours run time.... each screen.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 04:34 PM   #22
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Just to clarify a few things here before we all get buried in misinformation.
Plasma Not a good call for PC use. Basically they all suffer to varying degrees from burn-in effect and despite the varying technologies introduced to combat this they still have a way to go. They are also noisier and heavier than an equivalent sized LCD.
For TV use the PDP Plasmas from Pioneer have a life of 15,000 hours and upwards and a number of consumer models are starting to follow suit. HD units continue to fall in price and this trend is likely to continue.
LCD In 23" widescreen (which is what I run) these are a nice desktop monitor. BenQ and Mitsubishi make good quality units but you will pay dearly for them - at wholesale level they are both over $2k although there is a low res Mistubishi 30" around for about the same money. It is better suited for TV use than as a monitor.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 05:36 PM   #23
Paris Hilton
Custom User Title
Buy this unit, it looks pretty good :P
http://www.projectorcentral.com/JVC-DLA-HD2K-SYS.htm
Old 21-01-2005, 08:57 PM   #24
Thunder Kiss
Thunder Kiss's Avatar
There is a lot of misconception out there regarding plasma screens. Russellw's summation is pretty much spot on, however, many of the latest generation plasma panels have "half lifes" of between 30,000 and 60,000 hours. "Half life" being the point at which the panel reaches half of its original brightness and realistically the end of its useful life.
When all is said and done, I consider plasma to be far superior for TV/DVD viewing, while LCD would be better for data (ie computer) applications.
Thunder Kiss is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 10:41 PM   #25
Kapn_Kiwi
It is hard...
Kapn_Kiwi's Avatar
I recently purchased a new screen for a new computer. At the shop I was at, they had A)Dedicated PC LCDs/Plasmas
B)LCD/Plasma Screens which function as TVs, and
C)LCD/Plasma TVs with some sort of Video input for computer.
I personally would go with the 2nd, as they were a fair bit cheaper than the third, and there was very little difference in price between the first two.
Also, I'm a reasonably avid gamer, as are most of my friends, and they bitch on about so many things that aren't done in their typical fashion. I was told I shouldn't have got a wireless keyboard and mouse (I seriously can't feel the difference, so long as the receiver is pointed correctly) and was also given a bit of stick over my choice of a 17" LCD rather than a 19" Flatscreen CRT. While another 2 inches would have been nice, the ability to fit my monitor on my not-so-deep desk, as well as the fact that it's great for LANning (these guys have a real mission carting about their huge monitors) has meant that I think I made the right choice. LCD monitors aren't bad for gaming guys, I'd just let you know.
Kapn_Kiwi is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 11:27 PM   #26
Firefox7
T3 Terrorist
Firefox7's Avatar
I took a pic tonight of my projector and home cinema....the entry to your left is 2.4 metres high...to give n idea of the scale......the digital camera i have is crap....& really doesn't do the image any justice.....the shutter speed in the camera is shocking.....but here is my projector screen.....this is of course only around 180 inch....anything bigger is like watching tennis.....head left and right....but produces crytal images up to 350 inchs in perfect clarity.
Cheers.
Old 22-01-2005, 03:00 AM   #27
XRQTOR
XRQTOR's Avatar
The old man has a big Mofo projector, it's a fair bit wider than your's and twice as high. He's wanting to upgrade as soon as he finishes building his new house, movie room is 12m x8m. In reality there only good for watching sports events on, or decent movies not anything you'd use daily. Plus its a pain in the **** trying to keep the room dark during the day. I wouldn't rush out and spend 8 or 9k on one that's for sure.
Old 22-01-2005, 03:06 AM   #28
XRQTOR
XRQTOR's Avatar
I keep changeing my mind as to what i want it for, stated as a big pc screen. Now i want it to be an awsome pc screen and decent size tv/movie screen as well. Does anyone know the Lifes good website, one of our warehouses is next door to a lg storage facility, mainly repair's. Some of the plasma's and lcd's they get are fukin huge, seen a 21ocm plasma and a 168cm lcd. I'd seriously consider a 1oocm or thereabouts unit if i can use it for tv and pc screen with top quality in both aspects.
Old 22-01-2005, 09:20 AM   #29
rag top
rag top's Avatar
http://www.lge.com.au/index.do
Current Rides:
Old 22-01-2005, 11:57 AM   #30
Firefox7
T3 Terrorist
Firefox7's Avatar
I can go heaps wider and bigger than that....thats about a third of what it can do. But given the size of the room which is 5 metres by 6 metres, that size is just nice. Anything bigger is like watching tennis. When i play games with it out in the shed....I screw up the image size to max. I like using it for flight simming.....feels like your their. The projector is a Benq.....and i got it for under 5k. At 2500 lumens, you can use it during day.
Cheers.
