#1 | |||
![]() Join Date: Dec 2004
I'm suprised this hasnt been raised yet!!!!
The reprocussions could be HUGE!!! Quote:
WOW! Thats a big blow to the RTA.
God I hope some sort of uprising against the revenue-raising by the government comes to fruition over this.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
Old news. It is not a test case but if the RTA wants to push it to higher courts it could well be. At the moment it's every man and girl for themselves - i.e. don't pay the fine - take it to court.
#4 | |||
Hopefully it will be another brick out of the revenue wall of crap.
oh well if they get rid of cameras they'll just make factorys install gps systems in all cars and as soon as u speed your bank will be debited
Just out of curiosity AP, if this goes to the Federal courts, would you think the states are in for a REALLY hard time? Its been proven many times these cameras are unreliable and prone to error. If this goes to a federal court I'm betting that the states are going to have a VERY hard time proving the courts that the fines are valid 100% of the time.
I'm betting the states are trying to avoid a high court contest at all costs.
Official AFF conservative
Dangerous precedence....
A cup half empty... but full of euphoria. |
Wasn't it dropped because they couldn't get an expert on md5 hashes in time not because they proved the photos identification system was insecure.
The camera itself is not in doubt here, it surrounds the law regarding the administration of the photos taken.
If it does open up a loop hole, the state government will simply pass immediate legislation to close the loop hole back up again - that happened last year when a magistrates court threw out a photo as the algorithm only contained numbers when it was supposed to contain numbers and symbols. |
#10 | |||
Why? Because at this point I believe it would be a breech of an individuals constitutional rights... and then the Fed High Court can get involved. Once involved the States will have a hell of a time maintaining this revenue stream.
#11 | |||
Rider on the storm
They seem to be implying that someone tampered with the photo. Sounds like a conspiracy to me ![]() |
#12 | |||
Regular Schmuck
Major technicality and very impractical but also a fair defence. |
The interesting point presented, (which I dont pretend for one moment to understand legally), was the that it. was not so much the RTA was accused of having tamperd with the photo image, more that the RTA could not absolutely confirm that the image had not been tampered with.
#14 | ||
beep beep
Rodp is correct in that it was using MD5 hashing not MD5 encryption. What it does is takes a data input stream (the photo) runs it through the MD5 hashing application and spits out a 128bit number which should be reasonably 'unique' to this image. Basically it validates the authority of the picture because the digital image can be 'rehashed' to calculate the same figure. Changing just one pixel from Red=255, Green=255, Blue=255 (pure white pixel) to Red=255, Green=255, Blue=254, will impact the MD5 hash value and show that the picture has been altered from the true picture.
However because it is based on a 128bit range it is theoretically possible to generate two different pictures (two different inputs) which have the same MD5 resultant hash value. 128 bit = 2^128 = 340,282,366,920,938,463,463,374,607,431,768,211,45 6 variations However because it is such a large value it is often reproduced in Hexidecimal (0-F) rather than Decimal (0-9). The remoteness of two pictures being generated alike, is so rare it isn't funny, but you cannot guarrantee it, as it is mathematically possible.
Nothing to see here, move along, move along... |
#15 | ||
probably shouldnt be mentioning this, but im always up for adding fuel to the speed camera fire: my company has been contracted to investigate the rigidity of speed camera poles in windy conditions, and whether or not the vibrations encountered are outside the tolerance of the cameras...it appears that around 80% of them are failing!
Gone cruising
#16 | ||||
#17 | |||
although it appears that the movement usually results in an "error" being returned rather than a false reading, so its probably in the publics favour most of the time...but still, it raises yet another issue in an already troubled system
Gone cruising
#18 | |||
#19 | ||
Two > One
People are nieve if they think state gov's will push very very hard to not let this set a precedence. VERY HARD.
#20 | ||
The Guy You Love To Hate
Wouldnt it be great if there was a class action that accepted donations to push this to the highest court.
I know id have a grand to back it up straight away. |
#21 | ||
Hell yeah id back it up to.
#22 | |||
#23 | ||
Once they have found an expert they can call to show how md5 hashes work this defence won't work anymore will it?
#24 | ||
I am not going to pretend i understand much of the technobabble in this thread, but it certainly sounds entirely possible. And i guess its the old to prove "beyond ALL reasonable doubt" which clearly the RTA admits they cannot.
Im sure this will spark all manner of law suits.... but ppl would be well within their rights. |
#25 | ||
Mate i have no idea either but if it gets me out of a ticket should i visit NSW then i dont care lol.
#26 | ||
Supes
what I find funny is that there are a number of States in America that are actually banning Police Services from using Speed Cameras...when I was in California in May there was an article I was reading saying it was banned in that State and others were following, and the cameras were being removed on the basis that they believed that they no longer proved to be a safety feature on the road and just a revenue raiser, hence the argument that they are there to save lives (not raise cash) just wasnt working.
Yes I DO drive a Toyota |
#27 | ||
V8 Rock'n'Roll....
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
Does anybody know the actual law inregards to using digital or other imaging devices? I've been told by the guys who installed our security cameras and such that you need to be very careful with storing the imaged medium (video in my case, digital and analogue). I know the RTA have the ability to view images in different modes, infared and such. Is this actually "altering" the initial image taken? If the initial image is taken as a normal standard digital photograph, if the then apply an infared filter, does that actually mean the initial photo has been altered from it's first image? This may be a stupid question but I know that law is all about the exact phrasing and wording, (that's not even counting on preceedence).
1 owner 03 BA XR8 Manual Sedan 208.8 rwkw stock, update soon 20x8.5 fr 20x10 rr Rumble thanks to: Sureflo Exhaust - Stainless Cat's & 3.5in single catback system "Tell 'em the guy with the Blue Mohawk sent Ya" |
#28 | |||
Regular Schmuck
#29 | ||
Petro-sexual
The cameras use the sensors in the road as a primary measure to trigger the camera into action. The actual speed measurement device is located int he camera itself.
#30 | |||
beep beep
Imagine picking out 1 specific number out of a barrel with over 300 billion billion numbers. Not impossible but the odds are stacked well against you. The odds, most people just cannot comprehend. It is just too large.
