Old 25-10-2005, 09:09 PM   #1
get_bonked
XG UTE
Default Timing And Base Idle For Dev5
Can anyone tell me what they have their timing and base idle set at for a DEV 5 motor for max performance
94 XG Falcon ute. Phantom mica, bonnet scoop, lowered peddars suspension, 17" chrome quake mags, JMM DEV 5 kit, 2.5" exhaust and JMM extractors, minispool, XR6 ECU, autometer gauges, full pioneer stereo, 2x 10" subs, 2x 6x9 speakers. HAULS **** for a six and beats most eights. What more could you want?
get_bonked is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 09:18 AM   #2
Brenden
"THE" Workshop manager.
Brenden's Avatar
Hi Stace
Set base Ign Timing to approx 13 deg BTDC and base idel can be set with idle screw to 700-800 rpm and all should be good.
To set ignition timing dont forget to put engine into ignition set mode by bridging the top and bottom left pins on your diagnosis plug.
Jim Mock Motorsport
AME Albury carshow Horsepower Hero 2005
AME Adelaide carshow Horsepower Hero 2005
AME Shepparton carshow Horsepower Hero 2005
AME Melbourne Highest horsepower 6 turbo 2005
AME Melbourne Highest horsepower N/A 6 2005
All Ford nationals DYO 10.5 and over champion 2005
Brenden is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 09:28 AM   #3
neb
hibernating
neb's Avatar
What should the cam be dialled in to?
neb is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 12:46 PM   #4
get_bonked
XG UTE
Thanks for that Brenden. Ill let you know how it goes
Old 03-11-2005, 06:22 PM   #5
loxxr6
XB in parts...
loxxr6's Avatar
The specs come with the cam assuming you've bought it from JMM direct. From memory I think it was 42deg TDC
Old 05-11-2005, 07:45 AM   #6
jonbays
TL40 Wagon?
The timing in of the cam is usually done to the grinders spec on the cam card but typically for a JMM cam it will be set to 38-42 thou intake valve lift ATDC on no.1 not firing stroke obviously.
you can run them from 10-60 though and it will run. being mindfull of piston clearance if the heads shaved.
Advanced up to 60 thou is typically smooth but not feeling like it wants to rev.
Retarded 10 thou is idle gutless down low with a switch like feel at 3500 and loves to rev out.
Somewhere in between gives the broadest powerband and best results.
