View Poll Results: 2 L OHC Firing order
1342 4 66.67%
1432 0 0%
1243 1 16.67%
1423 1 16.67%
Voters: 6. You may not vote on this poll
Old 04-04-2006, 08:49 PM   #1
Smooth Gecko
Default 2.0 l, Firing Order
I have just done the head up on a 2 litre motor. ( to get a miss that was in there). No 2 Ex was bent badly. Bought a new valve, lapped them all in.
Still shake rattle & roll.
Havn't got a manual and was trying to recall if this was the motor in the back of my mind with an unusual firing order ( not 1342)
Just done it, have not changed plugs or done compression test yet.
I set the clearances @ 10 & 12 thou. but it misses straight away so shouldn't be this. The proper clearances would be nice too.
Smooth Gecko is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 10:53 PM   #2
Perana
Perana's Avatar
2.0L pinto had normal 1-3-4-2 firing order... it was the 1100-1600 crossflow's that had the strange 1-2-4-3 firing order.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 11:30 PM   #3
Smooth Gecko
Thumbs up Thanks
Good stuff "Perana XR8", had a sneaky feeling it was an older Ford motor.
Old 05-04-2006, 05:12 PM   #4
Smooth Gecko
Default Fixed
It was due to a sub-minimum clearance on the tip - ground setting on the non-sparking plug.! lol
( Went straight to it when I knew the order was right!)
