Old 10-04-2006, 09:08 PM   #1
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Default NSW Blue slip for change of records - what will they be looking at?
I have to get a blue slip for change of records to finalise my turbo conversion.
What are they (mechs) actually looking at in this inspection?
Any help would be appreciated.
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 12:18 PM   #2
BIGDOG
BIGDOG's Avatar
Engineers Certificate
BIGDOG
08 FG Sedan
04 Mazda SP23 Sedan
BIGDOG is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 12:33 PM   #3
Tote
Tote's Avatar
Firstly they will do a check on the engine and chassis numbers to prove the identity of the vehicle. After that it's basically the same as a pink slip so if any mods are done that require an engineers certificate you will need to supply one. Once you have the blue slip and the engineers certificate go to the RTA who will issue your registration and take a copy of the engineers certificate for4 their records. Your registration lable will have a code that indicates that an engineers certificate has been issued for the vehicle.
If you need a good Engineer I can recommend Bal Dohnt in Dubbo. (but dont try and pull the wool over his eyes, he's seen it all)
Regards,
Tote
Go Home, Your Igloo is on Fire....
Tote is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 06:31 AM   #4
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Yeah, I have the certificate.
Just didnt know how far they would go in looking at the car.
Just a few.
