Hi everyone,
Not sure if anyone else has experienced similar problems...my air conditioning works fine (as in ice cold) in cool to mild outside temperatures ...but if its a hot day it will be cold for a bit, then go warm...then may go cold again....warm again...and then may stay warm... its almost as if the outside temperature goes above a certain level my air-conditioning throws the toys out of the pram...really frustrating because this is when I need air-con the most gas must be ok as its still ice cold all other times... any ideas? I have had work done to the front when I bought the car from a damaged vehicle auction (its an AUII futura). Why would a hot outside temperature change the 'coldness' of my air-con? any help would be most appreciated... cheers J |
Fantastic Plastic
When using ya aircon , once i's running at a cool temp , flick the air switch to recycle the air in the cabin , takes alot of stress off the aircon and it seems to stay cooler, try that first anyway . ;) .
hmm...I only ever have it on recycle...not keen on the car fumes (I live on a busy highway and so get enough just living lol)
#4 | |||
Fantastic Plastic
AULTD
Just a thought, but maybe the engine temp is rising but not showing on the temp gauge and so a/c is cutting out to protect engine.
My LTD did this on the 40 degree day just when you really need a/c. When I pulled over and opened the bonnet with the engine running I must have let a bit of heat out and the a/c started working again. Drove another 20 kms and it happened again. Cooler days sees the a/c working perfectly, although the a/c man said that the pressures were o.k. gas wise but the compressor was not working efficiently and would eventually pack up. Been 3 months since and a/c still working o.k. |
#6 | |||
Fantastic Plastic
Turbo Falcon Fiend
make sure the A/C pump has a good earth.
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
thanks for your advice guys...looks like there will be no simple fix (as always lol)
