Old 28-04-2006, 12:33 PM   #1
DivHunter
DivHunter's Avatar
Default Why is it so (Dyno)
Quick question that will hopefully get a straight answer. How does the gear a car is run in effect the power output?
Speed cameras have changed the things we pay attention to and the things we regard as important. Instead of focusing on the dangers ahead, motorists feel that they have been relieved of responsibility for managing their own driving, and have ceded it instead to the mechanical intervention of the camera and other traffic signals.
DivHunter is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 01:48 PM   #2
BI6TIM
SnortPerformance.com
If it does at all it would only acount for a mnimal difference of say 1 or 2 horse power.
The only real difference between gears on a dyno is the speed that your rear wheels reach on the dyno.
However, having said that, it is best to run a car, on the dyno, in the gear that is closest to a 1:1 ratio. Then you are purely testing engine power at the wheels.
But like I said the difference is so small it's not worth worrying about.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 02:10 PM   #3
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
on a turbo car it can load the car lower in the rev range giving you a false torque hence power curve
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 02:23 PM   #4
DivHunter
DivHunter's Avatar
Load the car?
How do you explain a stock (187kw engine, not mine) R33 GTS-T getting 182rwkw in 3rd gear? That's around 40rwkw too high. What about a modified one with 200rwkw in 4th over 240rwkw in 3rd? Those were on different days, different dynos.
Old 28-04-2006, 02:42 PM   #5
jonbays
TL40 Wagon?
Originally Posted by Fairmont99
Load the car?
Your assuming that all dyno's and all days are the same and they are not.
Variance between them is huge. Its not so much the gear as the dyno and operator.
Old 28-04-2006, 02:49 PM   #6
DivHunter
DivHunter's Avatar
a 187kw car can't get 182rwkw though surely? That's almost no drivetrain loss. I think I confused you with the last bit I meant the 2 cars were on different days the one with 200 then 240 was on the same dyno same day.
Old 28-04-2006, 03:07 PM   #7
superpursuit83
KITTY Crew Member
superpursuit83's Avatar
true measurements are made in a gear with 1:1 ratio, normally 4th. Any lower gear creates a mechanical advantage thus increasing torque etc.
FOR SALE
BAII Super Pursuit 0083
Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block
Awesome exhaust by THE EXHAUST CENTRE MIDLAND
Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments
Now with full DOT approval and Permitted for road use
superpursuit83 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 05:39 PM   #8
jonbays
TL40 Wagon?
Not true the dyno is getting more torque applied to it for sure but it is supposed to calculate the power from the nm force and the rotational speed. It does make a difference as I have seen cars run back to back with just a change from 18" to 15' wheels make more power but it shouldn't its all about correction factors in the dyno.
Old 28-04-2006, 06:12 PM   #9
Black XR6
Formerly Black EX-R6
Black XR6's Avatar
geez, 15' wheels, freeking HUGE rims. He musta rolled the guards im betting.
""It's not the ideal way to win, but we got here, so yeah baby," said Kelly."
Stinking, mongrel, dog.
Black XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 06:23 PM   #10
xdclevo
The Fun Mobile
xdclevo's Avatar
I done many runs with my 3 sp auto, in 2nd and 3rd and it makes 1 or 2 hp difference maxx. Like stated, the dyno can tell with the different wheel speeds.
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 07:01 PM   #11
buickman
buickman
buickman's Avatar
[QUOTE=Black XR6]
They were back in the 70's & early 80's
Old 28-04-2006, 11:13 PM   #12
xdclevo
The Fun Mobile
xdclevo's Avatar
15'
Are you driving a monster monster truck. haha
408 cube Cleveland
10.7 @ 125 mph
2V powahhhhh
Old 29-04-2006, 09:55 AM   #13
bazzalong
was the dyno in shootout mode? if not the figures can be played with.....
eg a 100hp engine could be made to look like it is a 200hp engine...
next time look at the dyno screen, and see if it says "shootout mode",
if not, they could be having you on
bazzalong is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2006, 10:01 AM   #14
superpursuit83
KITTY Crew Member
Sorry looks like i am all torque
FOR SALE
Old 29-04-2006, 10:02 AM   #15
Walkinshaw
Two > One
Walkinshaw's Avatar
As it should be. There are a few dynos arround that seem to add 20rwkw when tested in a lower gear. Ie testing a manual in 2nd gear to claim 180+rwkw
Old 29-04-2006, 11:19 AM   #16
sfr rob
sfr rob's Avatar
so basically, dynos are lying pieces of crap, and are usless apart from when tuning.
I am sure there are ways to exploit dynos with diff ratios etc, probably what the dyno queens do.
hahaha
Old 29-04-2006, 02:45 PM   #17
Walkinshaw
Two > One
Walkinshaw's Avatar
Any tuning house worth a grain of salt will agree with this.
Old 29-04-2006, 02:52 PM   #18
jonbays
TL40 Wagon?
hahaha
Yep you got it right. In a nutshell YES.
Old 29-04-2006, 03:29 PM   #19
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I would say only a small power difference due to the faster turning tailshaft, diff centre, axles & wheels absorbing a bit more power. 18 vs 15 inch rims will be heavier with the weight further from the centre so they will actually take more power to accelerate.
Old 29-04-2006, 07:44 PM   #20
LTDHO
The one and only
LTDHO's Avatar
exactly
Tuned by CVE Performance
