I'm BOSS
Location: Where all Fast Fords are From, Northern Melb.
Hey Guys,
What is the best way to debadge a car without wrecking the paint job. Is it easy enough to just peel the bagdes off or is there a techneque to should use??
![]() ====Past Rides==== '04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW '04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph '92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust. '06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust. ====Present Ride==== '10 FPV GS Ute ZF 6spd:#108. With all the fruit. |
Old rookie
the badges will just pull off. then just clean off glue
#3 | |||
I have heard the best way is to use a hair dryer.. that way you won't pull any paint off.. then just clean the remaining glue off...
#4 | |||
As in 'best there ever'
yer hair dryer is the way to go...make sure you check if your badges have the pins behind them tho...i;ve made that mistake once lol
#6 | ||||
![]() Woz, you plug it into a power point and use the heat to unstick the glue which is generally (not always though) what badges are held on by...
I'm BOSS
Thanks guys i thought that adding a bit off heat would make it a bit easier.
Whats the best stuff to get the glue off tho, a swab off metho or should i use wax & grease remover......
#8 | |||
The other...? I don't have any hair. What's a hair dryer? ![]() |
owning V8=having no $$$
Woz and Fiery at it again...
![]() Be very carefull when pulling them off as I have taken paint off my old AU XR6 when I tried to pull off the badges, stupid fingers....
Weekends - 1965 XP 302 sedan... ![]() Weekdays - 1980 323 Mazdabator complete with cheese cutters & FF sticker :dr_Evil: The Reality: 13.1 @ 106mph.... The Goal: somehow get into the 12s!!! :sm_headba www.qldsuperkart.org |
they call me Tibbo
with fishing line in a sawing action held taught against the badge will slice the double sided tape and/or sikaflex
Then prepsol to sofhten the residue, just wax after you are done to combat the prepsol
Fossil fuel consumer
![]() Join Date: Jul 2005
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
I took mine off by using the hair dryer method - poured water into the back of the badge (where the tape is) and let it bed in for a minute, then smashed the crap out of it with a hair dryer! Nah, turned the hair dryer on, and heated the back of the badge evenly, while not holding it too close to the paint. With a bit of wriggling of the badge, it will eventually come free but i found it took a while, with the 'XR' badge on the boot taking AGES! I then used some of that 'orange' guck removing stuff you can get from Coles or wherever, and a warm wet cloth, and about 15 minutes of elbow grease per badge.
You can also use fishing line, and i used whipper snipper cord on one of them, which pulled the badge off in seconds, but this method left virtually ALL of the backing glue on the metal (whereas the hairdryer left virtually nothing) and took freaking ages to remove. I recommend the hairdryer method. |
#12 | |||
The Vengeful One
![]() Join Date: Apr 2006
#13 | ||||
#14 | ||
exactly
(to the 'careful with the hairdryer' heat damage thing) |
#15 | ||
Hairdryer is the best method. Start to heat up the badge. Once its warm keep the dryer going and start to wiggle the badge. Eventually the glue gives and you can pull the badge off. To clean it, use Metho. I did this, never damaged the paint and cleaned off all the glue. All i did then was apply some polish to the paint where the badge was and that was it.
Pretty easy
FG2 XR6T KIA Cerato 2022 Kawasaki Z900
#16 | ||
I used the hairdryer method to pull the "5 Litre V8" badges off the front guards. Works a treat. Clean the leftover glue off with prepsol ,then Scratch X and a wax. You'd never know they were there.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT Last edited by fairmont1998; 11-05-2006 at 09:00 PM. Reason: spelling |
#17 | ||
and you won't regret the clean look, i found it made the spoiler have far better definition. I still have to remove the side skirt badges, too lazy though :(
The 'F' from 'F A L C O N' fell off my ba when i had it, i should have de-badged that one at that point ;p Whereas the 'F A L C O N' badging that used to be on the bf looked like it had been put on by someone with their head tilted 43degs to the left and guzzling chardonay |
#18 | ||
Come fly with P.S.I...
Eucalyptus spray to get the glue off works like a treat and takes bout 5 mins and wont damage your paint.....
FG Turbo ute..lowered,20's Turbosmart Bov,Plazmaman piping,Flash tune coming...
#19 | |||
#20 | ||
miss my V8
I used boiling water to remove all mine, just pour it over the badge, then gently wriggle it off. Probably just as effective as the hair dryer, maybe less chance of damaging the paint??
While the glue is still soft it seems to peel off relatively easily, but eucalyptis oil works a treat for the more stubborn bits. |
#21 | ||
I wouldn't have a clue how to do it mate...
#22 | ||
Old enough to know better
I use the hairdryer and dental floss method. Heat up with hairdryer and then cut through with dental floss. The dental floss is pretty fine and seems to cut well
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
#23 | ||
Formally Kia Chaser
Why do you want to take the badge off? It must be a commodore? Or a daihatsu with a VS body kit.... lol
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#24 | ||
I'm BOSS
Well i debadged that car today. Used the Hot water method as mentioned above post #20. Works awesome, took all the glue off aswell so no cleaning to do afterwards. Will give it a good wash and polish soon, should bring the paint up imak.....
#25 | ||
Nat D
lol easiest way is to use fishing wire and then just polish the left over glue.. took about 2 mins.. including finding fishing wire
old ride#1: ED XR6 5 speed-gone to new home:( old ride#2:dumped EL fairmont 5l new ride: Winter white AU2 XR8-manual |
#26 | ||
Yeah I used fishing line, to remove my badges.
#27 | |||
#28 | ||
Does anyone know if EL GLi's badges are on with pins also??
#29 | ||
not sure, go for a hoon down to your local ford wrecker and have a look at one
#30 | |||
meh
1992 EB II XR6 2004 BA XR6 Turbo |
