Old 24-05-2006, 03:23 AM   #1
CSV_LS1
I used to have a nice car
CSV_LS1's Avatar
Default :HELP: My New Hard Drive Aint Showing Up On Windows
I bought an extra hard drive to have as a slave. Problem is i have no idea about computers :yeees: I've attatched it and on setup it shows up as a slave but on windows it doesnt come up. Is there something i'm missing? I'm clueless with computer tech stuff so any help will be appreciated.
Thanks
CSV_LS1 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2006, 07:28 AM   #2
FPV329
Workin' for the BOSS
FPV329's Avatar
You may have to go into your BIOS and adjust some settings there. It's possible depending on your Windows version that it does not support the size of the drive. You may have to activate large drive support for it in your BIOS. You may have had to change the jumper on your master now that you are adding a slave also.
Ford Racing Alloy Blocked Custom Built 5.4L Harrop/Eaton Blown Boss BA XR
FPV329 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2006, 08:51 AM   #3
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
have to create a partition first, then you will see it in My Computer, then you can format it. The drives you see in My Computer aren't the actual drive, it's the partition, so if you don't have a partition, it won't show....
Right click on My Computer, then click Manage, Then on the left part of the new window, click Disk Managment... you can do the rest from here
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2006, 09:19 AM   #4
ltd
Force Fed Fords
ltd's Avatar
That's right. Disk has no partition.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2006, 12:01 PM   #5
CSV_LS1
CSV_LS1's Avatar
Thanks alot guys. Wasn't so hard after all. Appreciate it.
