Old 09-09-2006, 12:03 PM   #1
Ashes
Default Low beam problem
Tried seaching for this problem but drew a blank.
I have an AU3 wagon and the low beams are not working. The following happens on the various light settings
- park lights - both park bulbs are on - good so far
- low beams - only park bulbs are on
- high beams (stick pushed forward) - park, low and high beam bulbs on
I've checked the fuses, swapped them around and get the same result.
So it seems the fuses are fine, all bulbs are fine but the low beam globes dont light up.
Any ideas? I'm guessing it's switch related
Ashes is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2006, 12:08 PM   #2
Sapper
Back to the AU
Sapper's Avatar
Had exactly the same problem on my 'old' (2005) corolla, to the letter. For me the problem was the connector had fallen out of one light and the other light had a blown globe. Funny thing was that for me both headlights failed at the same time (though not while i was driving).
Dunno if your problem is the same but have a check anyway.
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU
2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth
Sapper is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2006, 12:16 PM   #3
LUXO_8
windsor user
hard to explain.........low beam bulb has 2 filaments
so when you're on lowbeam, the lowbeam circuit isnt working.....
when you put it to highbeam, the high beam circuit is working..........
i'd try replacing the bulbs........something sounds iffy though if both arent working and its just happened
Old 09-09-2006, 02:03 PM   #4
Ashes
Thanks for the quick responses. I think I may have lost one low beam before the other, not at the same time. The two filaments make a lot of sense. I've got some replacement globes and will put em in tomorrow. Hope it's that simple.
Old 09-09-2006, 02:08 PM   #5
LUXO_8
windsor user
ah if they went out at different times it definatley sounds like blown filaments in the globes....
change them and it "should" fix it
Old 10-09-2006, 01:53 AM   #6
Baboon_AU
Baboon_AU's Avatar
change both globes (the bigger ones)
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 10:58 AM   #7
Ashes
Thanks, replaced the globes, all OK. I didn't realise there were two filaments. They both seemed to go quite close to each other. Is is a case of one globe blown, putting more strain on the other causing it to fail shortly after?
Old 10-09-2006, 11:21 AM   #8
LUXO_8
windsor user
good to hear the problem is solved...
it could very well be a combination of the globes being the same age, and the extra load once one is blown...
a globe works by heating the filament in a sealed capsule of gas.... that filament is not going to take being heated and cooled for ever
Old 10-09-2006, 12:51 PM   #9
TwistedEL
TwistedEL's Avatar
If both globes are of the same type and installed at the same type then really there should only be a few hours life difference (in a perfect world)
Old 10-09-2006, 04:27 PM   #10
Baboon_AU
Baboon_AU's Avatar
and it is really important when installing globes that u do not touch the glass as this will stuff the globe up and will last a very short time. if u do touch the glass, clean it with metho straight away
Old 10-09-2006, 04:31 PM   #11
LUXO_8
windsor user
misconception.....
touching the globe wont stuff it......
what it does do is leave fingerprints on it which cause the capsule to not emit enough light, as its basically "tinted" with your fingerprint...
just wipe clean with t shirt or a tissue and it'll be fine
Old 10-09-2006, 05:37 PM   #12
chief
FTF Club Moderator
chief's Avatar
Touching the glass only really effects theatre lights, (in cases of the bulb exploding). As wayne said just clean the globe first then use it.
Albert Einstein:
Fords in the Park 2010
Old 10-09-2006, 08:22 PM   #13
Ashes
No worries, I was careful not to touch the globes.
Old 10-09-2006, 09:08 PM   #14
GK
Walking with God
GK's Avatar
Glad you got it sorted!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
