Old 21-09-2006, 12:44 AM   #1
89 S-PACK
Exclamation tension settings for 86 telstar
hi i have just changed the motor in my telstar after dropping a valve and doing some serious damage to the bottom end so a new motor was the only choice atm
im using a fe motor out of a mazda 626 88 model i think. but all the accessories lineup and so does the bellhousing and its all identical
what i need to know is the tension wrench settings dont say up tight cos that aint good enough
all the engine mounts and the gearbox settings
manual flywheel bolts
clutch bolts
belhousing bolts
starter bolts
bracket that holds the driveshaft to the block on the drivers side
air con\alternator bracket bolts
(both of mine live on the front next to the radiator)
Still about lol...
02 (VX) Holden Commodore Equipe series 2 S/wagon.
Manual, Lsd, Catback, Svsi lpg.
still a nice reliable upgrade from the old magna..
89 S-PACK is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 02:39 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
http://www.mx6.com/forums may help
if not this is the closest nms I can offer from my 86 to 88 suppliment
engine damper mounts sub frame 62 nm / to engine 53 nm /
torque stopper casing to engine 77nm/bracket to body 55 nm
front and rear mount to engine 30 nm to subframe 53 nm
manual flywheel bolts 105nm
clutch bolts pressure plate to flywheel 27 nm
belhousing bolts 119 nm
starter bolts 40 nm
bracket drivers side ......called intermediate shaft mount 63 nm /cv lock nut 240 nm
air con\alternator bracket bolts .... none given
My car goes Brumm Brumm
