Old 05-09-2007, 08:33 PM   #1
Nashio
Question laser KQ 2001 not starting after 5 min running
Have laser KQ 2001 5-door model, when starting up for the first time (when the engine is cold ) car starts up without a problem, and will run till turned engine off, if the engine is warm it will not start up any more needs to cool off
things I have done:
Replaced thermostat and belts about 5-6 weeks ago
Battery is new as old one died about a week ago (old battery)
Battery voltage is:
no load 12.6Volts
Starting 11.2Volts
Running 14.2Volts
Checked and tested petrol pump OK
Problem started after replaced battery but I suspect may have been there and it caused battery fault
will apreciate any help / hints what may cause this sort of problem : used:
Nashio is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 03:50 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
wait for vippen to add comment
a guess
coil or dissy problem leads or plugs
fuel filter clogged/water
starter motor ?? maybe
if EFI there is a temp sensor on the inlet manifold related to the tps and engine management system this may be faulty
if carby then petrol vapor lock if you are stop starting (as in going from place to place ) water and wet a rag and put it around the carby to get going again after cranking for a while ...
My car goes Brumm Brumm
Old 09-09-2007, 08:00 PM   #3
hitork
Injected
hitork's Avatar
I don't see how changing the battery can have this affect :s
U should probly be looking for somthing unrelated like water in the fuel. Have u filled up at any old/no name peterol stations latley?
hitork is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 08:36 AM   #4
Conquest_Tsi
Could also be leaking injectors, may drip/leak after turned off causing no/hard warm starts.
Hows fuel consumption been lately?
Conquest_Tsi is offline   Reply With Quote Multi-Quote with this Post
