Ok Guys I'm sick of my old shitbox auto and
have bought a AU manual conversion kit from the wreckers. It includes everything from T5 to manual ECU. The kit comes from a AU II ute. Can any of you guys give any tips when making the change over or anything I should look out for? ![]()
Au Falcon DRB GT40 #64 |
Boost Addict
lotsa beer ;)
nothing too over the top really, hardest bit will be the wiring, which u know a little about is also a peice of cake hotwire the neutral switch and reqire the reverse lights, simple as that. expect a lot of grases on ur nuckles and make sure ur vocabularey of swear words is up to scratch
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#3 | |||
BA GT-P Owner
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
they call me Tibbo
ute and sedan tailshafts are different
The manual has a dampening ring on the tailshaft, so if you have a sedan getone of those Don't forget to order the spigot bearing from Ford
they call me Tibbo
Another thing too:- Depending on what series your car is, you might have issues with the SII ECU going into a smartlock AUI
Also dont forget to get your key reprogrammed to match the new ECU and BCM
We just did mine over to manual and its the best mod i've done to the car.. its completely different to drive in a good way.
You have to go to ford to get your key reprogrammed to the new ECU, the car will not start and will probably immobilise itself if you don't. |
Fantastic Plastic
Might be worth adding a nice thick plate of steel for the firewall where the cluch is while your at it , save the dreded droping clutch/cracked firewall drama later... just a suggestion , allthough you've probably allready thought of that anyway ? , cheers ;) .
Hi albanycobra, how much did this kit cost, if you dont mind me asking? Did you just get it from a wreakers, or are these actually available as a full kit? i am just trying to decide what would be the next mechanical mod i look into doing.
Trouble encounted so far
1- The Auto tail shaft is to long, will need cut and shut. 2- series 2 pedal box has different brake booster stud pattern, will need drilling. We got the box fitted and all is well so far. Will just put inhibitor switch in nuetral to get car going before changing wiring and ECU. The conversion kit was $1830 from Wollongong wreckers NSW.
XR8 M8
hi guys, i got a question thats got nothing to do with the manual conversion, but though since its about transmission i did'nt want to start another thread, soo here's my question..
Is it possible to throw a 2006 XR 6spd auto transmission in an AU
The King of the jungle doesn't whistle.. he roars!
#11 | |||
not here much anymore
RAM 1500
#12 | ||
XR8 M8
hmmm, how much modification would someone be looking at, and is it worth the cash
To be honest I dont know much about the actual work involved, but I think at this particular point in time your biggest problem would be finding a box? They go for around $8k from Ford.
RAM 1500
#14 | ||
Boost Addict
the biggest problem will be the electronic controller, as for the mechanical side of things i dont see a reason why it shouldnt fit quite easily.
#15 | |||
Fantastic Plastic
#16 | ||
Boost Addict
there would be three possible solutions to that problem:
1: standalone TCU 2: BA 6 speed ECU, which ONLY controls the transmission, not the engine (BBM would be the easy part to make work, VCT would be the biggest issue) 3: full manual valve body and shifter, eliminating electronic control
#17 | ||
they call me Tibbo
the trans tunnel on the AU would be too small aswell....
#18 | ||
Back onto the original thread, How many different tailshafts are available
for the AU, It seems there is an Auto one, a ute one and I can only assume there is a dedicated manual tail shaft for the sedans?
#19 | ||
yeah i would think the sedans would have had one made just for them, but im not sure on the wheelbase of the utes, whether or not they are the same length as a sedan...your best bet would probably be to find either the car you got the box from, if it had a tailshaft in it, or find a wrecked manual sedan...unless someone else here knows somewhere else you could get one
#20 | |||
Ute tailshafts are different. |
#21 | ||
I suppose cutting the tailshaft down will be cheaper than
Buying a Gen Ford manual tailshaft new.
#22 | |||
they call me Tibbo
#23 | ||
Where do I find a manual AU sedan tailshaft? They'd be rare as hen teeth,
unless a shaft from another series fits. We tried an E series auto shaft and it was to long aswell.
#24 | ||
they call me Tibbo
I just rang the local and they put it on the Parts Hotline... 30 secs later I was on my way to pick it up.. While they are rare'ish I didnt have any trouble finding one
#25 | ||
a good tail shaft place would be able too fabricate a newy if you were desperate.
#26 | ||
Yeah thats way I'll have to go I suppose in regards to the tailshaft.
I was hoping to leave the Auto inhibitor switch plugged in and select Neutral and leave the main Autotrans plug hanging, I suppose doing this will bring the engine light on ? maybe I should bridge the start side of the inhibitor switch and set the switch to drive? Anyone fooled with this when it comes to AU's? Was hoping this thread could be a good technical resource for all considering the conversion. This what I've got so far AU sII manual trans fits AU SI -straight fit no mods AU sII pedal box requires booster holes redrilled to suit AU sI AU auto tailshaft wont fit, Requires shortening by about 50mm Auto centre consul just needs the gearstick boot insert fitted Things still to sort 1-Inhibitor switch (what to set it at) 2-Final tailshaft lenght (maybe someone with manual can measure theirs?) 3-I have a manual ECU from the series 2 (will confirm later if swap over is possible. Thats really all that is left to do. Can take some pics as car is on the hoist at the moment.
#27 | ||
Boost Addict
1: hotwiring neutral switch to perm on will not bring up engine light on
do not wire in D position as it will inhibit u from starting car ;) 2: sorry car is at mechnanics cannot measure, i got a custom light weight made up for 350 bucks ;) 3: cannot use Au S2 ecu in Au S1 due to smartshield/smartlock systems
#28 | ||
Will having the main Autotrans plug (controls solenoides and the like) unplugged bring on the engine light?
Evil chief - So you just unplugged the inhibitor switch completely and hot wired the harness plug? or did you leave the inhibitor plugged in and selected park/neutral positions?
#29 | ||
Auto tailshaft has to be shortened 60mm.
Price quoted $250 including new uni's or a Ford Gen is $745.
#30 | ||
Boost Addict
left inhabitor switch in and crosswired it to be enagged permanently.
the harnes plug becomes obsolete, except for the reverse switch
