Just picked up a set of 4 King superlows for the XR8. How much lower will the car sit with them fitted?, also will the shockers need to be replaced?
#2 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
![]() shockers should be fine .. just replace them with the shorter ones when there worn out ![]()
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
#3 | |||
![]() Join Date: Dec 2004
It will look like mine basically. Even though I have SSL in the rear it never really dropped all that much different to the SL's.
Just had a look at your lastest pics in "show us your AU", so basically it will look something similar?. Thanks.
yup, about that height front and rear
#7 | |||
![]() Join Date: Jan 2005
Lows/factory XR end up around 665mm from the ground to the underside of the guard lip.
SLs end up around 645 to 650 SSLs around 635. Stock height varies from AU1 to AU3, but anywhere between 680 and 710 is "normal"
It will look like mine, but maybe a bit higher in the back as i have the gas tank which makes it sit a little lower at the rear then the front!
Im starting to feel the ride it's bumpy as all hell n my shockers were fine before i had put the King Springs SL in! So it's up to u, but maybe u could get either air suspension or air lift shockers! Cheers Simon PS: Did u find those clear repeters? |
