Old 17-02-2007, 12:16 PM   #1
Piotr
Non-Regular Member
Default Adjusting Headlights
Just wondering if anyone knows how the head lights adjustment works. I found the 2 bolts to adjust each headlight but have no idea which way to turn them.
If anyone knows how they work could it would be great
Old 17-02-2007, 12:18 PM   #2
joshf2
striped
joshf2's Avatar
or you could just trial and error it
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 12:26 PM   #3
The Dok
The Dok's Avatar
Indeed "trial & error" is the best method if you've not done it before on this model, but ensure you are in a dark area (dusk or evening is usually best) so as to ensure you dont "over-adjust" them. Rough rule of thumb is @8-10 ft from a fence or roller door (dark surface) on even ground. I have a proper (adjustment distance) guide (pdf), if you want me to email it to you, just PM me with your email address. _2:
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 12:36 PM   #4
LUXO_8
windsor user
be very careful, IIRC the adjusters on these are somewhat fragile......
do not use a cordless / electric screwdriver or you'll strip threads.....
Old 18-02-2007, 12:04 AM   #5
Lplus
Lplus's Avatar
The ones in the back corners are the side to side adjusters and the ones low down in the middle are the up and down, as far as I remember. Damned if I can remember which way they move though, only that the up and down is fairly sensitive and the side to side isn't. A wall or door and trial and error, I'm afraid. Don't forget to check the level adjuster is set to full high first.
Lplus is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 02:13 AM   #6
Piotr
Non-Regular Member
Excellent thanks for that. Ill give it a go tomorrow evening
Old 18-02-2007, 09:49 PM   #7
Piotr
Non-Regular Member
Adjusted the headlights just them. Thanks for the advice guys, I used a screw driver to turn the bolts and it took all of 30seconds to get it right.
Much better lighting at night
Old 19-02-2007, 01:12 AM   #8
Ives
Ives's Avatar
Oh, that was pretty easy then.
